trust wheel patch from inside?
Old Jan 15, 2016 | 09:01 PM
VikingTrad3r's Avatar
VikingTrad3r
Oil Producer
Default trust wheel patch from inside?
guys i took my dsr wheel in to be repaired. losing air while in storage. had industrial sized staple in wheel, 2holes.
patched from inside. i have only ever used plugs on my trucks.
is this safe for high speed?
Old Jan 15, 2016 | 09:05 PM
hcbph's Avatar
hcbph
You're saying they took the tire off the rim and removed a staple from the tread area then put a patch on the inside of the tire. Prior to plugs, that's how they patched tubeless tires with a puncture in other than sidewall areas. I've run them out west when there was no daytime speedlimit and probably around 100 mph for some distance and never had a problem. I've also run some tires in excess of 50K miles without and issue that was patch related.
Old Jan 15, 2016 | 09:16 PM
antfarmer2's Avatar
antfarmer2
I will never use a plug putting it in can mess up the cords only inside patches for me!!!!!
Old Jan 15, 2016 | 09:20 PM
VikingTrad3r
Oil Producer
thnx. case closed
Old Jan 15, 2016 | 09:41 PM
383vett's Avatar
383vett
The patches that have an integrated plug work well. They look like a mushroom. Best of both worlds.
Old Jan 15, 2016 | 09:43 PM
cv67's Avatar
cv67
St. Jude Donor '05
either are fine Ive been using plugs for many yrs never had one leak
Old Jan 16, 2016 | 08:58 AM
3JsVette's Avatar
3JsVette
Also check out the info on the Tire Rack site about what should and should not be repaired. It's always better to error on the side of caution.
Old Jan 16, 2016 | 02:10 PM
Klondike's Avatar
Klondike
I've had plugs ruin the steel belts shortly after a tire "fix". They don't leak air, but the tread warps and starts wiggling the car at low speeds and thumps loudly at highway speed. Turns a tire with lots of tread left into a piece of junk! If it's a little nail or piece of wire, it probably didn't cut any or many steel fibers, so an inside patch will stop the air leak and the steel belts won't be damaged by poking a bigger hole in the tire with a plug.
To trust wheel patch from inside?
