Should I pull the trigger?
Old Aug 30, 2002 | 12:48 PM
scorp508's Avatar
scorp508
Default Should I pull the trigger?
Just got a 383 shortblock quote from Golen Engine Service. Now is the part where you have to decide how much you want to give your cash a new home. :)
1-Piece Rear Main / Rollercam 350 Block
Eagle 4340 Forged Crank
Eagle 4340 Forged H-Beam Connecting Rods
JE Forged pistons
Speed Pro Plasma-Moly Rings
Block: Thermally cleaned and Stainless-Steel Shot. Inspected by MPI process. Bored, honed and pressure washed. Clevite cam bearings and pioneer brass freeze plugs installed
Block Preparation
The block is visually inspected and MPI (Magnetic Particle Inspection) tested for casting flaws and/or cracks. It is then bored for oversize pistons using a custom-built Rottler FA2-AVB automatic precision boring machine. Finish sizing is accomplished using a state-of-the-art Sunnen CV616 power stroke honing machine.
I was quoted this being good up to 750hp and 8000 RPM if I ever needed it.
[Modified by scorp508, 12:06 PM 8/30/2002]
Old Aug 30, 2002 | 12:58 PM
Mr. Magoo's Avatar
Mr. Magoo
From: Damn taxes! Pimpin' Ain't Easy in Massachusetts
2018 C4 of Year Finalist
St. Jude Donor '03-'04-'08-'09
Default Re: Should I pull the trigger? (scorp508)
How much??
lite blue's Avatar
lite blue
St. Jude Donor '12
Sounds like a winner.
I'm jealous :D
You're gonna have fun! :cheers:
Old Aug 30, 2002 | 01:04 PM
scorp508's Avatar
scorp508
How much??
$3500. If I give them $1000 deposit tomorrow it will be done in 1.5-2 weeks.
Old Aug 30, 2002 | 01:05 PM
FoolCrzy's Avatar
FoolCrzy
:yesnod:
Old Aug 30, 2002 | 01:10 PM
Mr. Magoo's Avatar
Mr. Magoo
Default Re: (scorp508)
How much??
Damn that's a lot of money........................do it!! :D
Old Aug 30, 2002 | 01:12 PM
scorp508's Avatar
scorp508
Default Re: (Mr. Magoo)
:sad: :yesnod: :sad:
Old Aug 30, 2002 | 01:13 PM
ZylaRace's Avatar
ZylaRace
There is nothing wrong w/ this combo. Is there a Q here?
These parts are more than strong enough for an NA task. You could spray this combo if you wanted to.
You could do it for less $, but time would be a factor.
Old Aug 30, 2002 | 01:16 PM
scorp508's Avatar
scorp508
Is there a Q here?
Nope. No Q's, just that crummy moment when you have to give up the $ before you can play with it. :) He told me I could throw whatever I wanted at the JE pistons for spray and be fine (with the engine at least) within those limits listed above.
Old Aug 30, 2002 | 01:21 PM
vvv90's Avatar
vvv90
$3500 for a bullit proof shortblock @ 750 HP is awesome! You'd be a fool not to do it ! :cool: :cool: :cool: :cool:
Old Aug 30, 2002 | 01:29 PM
Mr. Magoo's Avatar
Mr. Magoo
Scorp repeat after me...............YOU ONLY LIVE ONCE!!!! :)
Old Aug 30, 2002 | 01:38 PM
vader86's Avatar
vader86
Buy it. :yesnod: :yesnod:
Old Aug 30, 2002 | 01:50 PM
buzzbomb's Avatar
buzzbomb
What about balancing? :confused:
Old Aug 30, 2002 | 01:52 PM
STL94LT1's Avatar
STL94LT1
If you have the $$.......go for it.
Old Aug 30, 2002 | 01:53 PM
scorp508's Avatar
scorp508
This is assembled ready to drop in and go.
Old Aug 30, 2002 | 01:57 PM
MrJay's Avatar
MrJay
Why dont you just fix your engine, it would cost less then that.
Jay
Old Aug 30, 2002 | 01:59 PM
TA's Avatar
TA
Default Re: Should I pull the trigger? (MrJay)
Jay
What fun would that be? :jester
To Should I pull the trigger?
Old Aug 30, 2002 | 02:00 PM
MrJay's Avatar
MrJay
You are right TA......lol
Jay
[Modified by MrJay, 12:03 PM 8/30/2002]
Old Aug 30, 2002 | 02:11 PM
YLO Z06's Avatar
YLO Z06
2023 C5 of the Year Finalist - Modified
How much with a cast crank? Do you really NEED all forged internals?!? That is a lot for just the bottom end...
Old Aug 30, 2002 | 02:13 PM
scorp508's Avatar
scorp508
My original plan was to build a supercharged 383 when I was able to get the money together. If I do this now I won't have to do the bottom end again as long as I don't bump the CR too high now.
