SYS code on dash... WT heck
Old Jan 19, 2016 | 04:12 PM
krackenvette's Avatar
krackenvette
Default SYS code on dash... WT heck
1993 Vette, new battery, alternator shows 14.2 output via voltmeter at alternator and at battery. Dash meter shows 14.1 at idle, out of gear.
Car uses battery tender daily, and this is the first time I drove it in a month.
ANy ideas? Runs fine..
Old Jan 19, 2016 | 04:19 PM
WVZR-1's Avatar
WVZR-1
You might just disconnect battery and the Tender, wait let it rest and then reattach battery less the Tender, try again. Does it accomplish much? Maybe - just maybe!!
Then the Tender again. What brand Tender? Model?
Old Jan 19, 2016 | 04:28 PM
krackenvette
I disconnectex tender yesterday, as it was on it since last driving, early Dec. Schumacher 1.5A XM1-5-CA.
Voltage reads 12.98 now. Not running. Cars off
Old Jan 19, 2016 | 04:51 PM
Kevova's Avatar
Kevova
Aftermarket radios will turn on SYS on display. You need to find out what code is stored.
Old Jan 19, 2016 | 04:59 PM
krackenvette
No codes. Just ran a scan with TTS Datamaster. I do have a JVC din 2. Been there for 16 years.
Old Jan 19, 2016 | 05:02 PM
antfarmer2's Avatar
antfarmer2
I would have the battery tested and the alt just to be safe the sys light will flash sometimes when the battery is saying goodby evan new batterys can be bad.
Old Jan 19, 2016 | 05:14 PM
WVZR-1's Avatar
WVZR-1
But you didn't disconnect the battery cable(s) to let it rest. Right?
I believe that an extended stay on a Tender can cause precisely what you see. The system I believe is accustomed to a conventional charge to keep the battery at charge and the very slow 1.25 or 1.5 SLOW charge likely tricks the system into a value it's not accustomed to seeing and it triggers the SYS as an ERROR.
To avoid maybe taking the battery out turn on the lights for 5 - 7 minutes with car NOT RUNNING, turn lights off and crank the car. If it doesn't start it's time for a battery(warranty if new or recent) for sure. If it cranks and runs check the alternator output then, react as you see fit.
Old Jan 19, 2016 | 06:01 PM
krackenvette
DOing the headlight test. I do have the glass European housing and Osram bulbs. I will do 5 minutes.
Battery is maybe 8 months old.
Old Jan 19, 2016 | 06:10 PM
1993C4LT1's Avatar
1993C4LT1
I would scan the codes(if there are any).
Old Jan 19, 2016 | 06:45 PM
krackenvette
All I get is the standard code 12, battery... Normal.. I will leave the tender off for the next couple weeks and see what happens. I will then fly out for a couple months....
Old Jan 19, 2016 | 06:58 PM
wzschirnt's Avatar
wzschirnt
Bad/low battery. My 96 needed the 'tender' on it or it would get low after a month or so and not start. Gave the "SYS" code when it was jumped off which went away when the battery was charged up again.
My 93 sits for a month or more; battery stays up just fine with no tender; no "SYS" codes.
Good luck.
walt z.
Old Jan 20, 2016 | 10:20 AM
krackenvette
Had alternator tested at parts store. Passed.
Drop tested battery via watching voltmeter during crankinh. Never went below 10 volts.
Did find blown LH crtsy 20 amp fuse. Think that could cause sys flashing?
Old Jan 20, 2016 | 10:26 AM
antfarmer2's Avatar
antfarmer2
I would sure replace it and find out.
Old Jan 20, 2016 | 10:28 AM
krackenvette
I did replace it and will drive within an hour. At work right now.
Old Jan 20, 2016 | 10:34 AM
antfarmer2's Avatar
antfarmer2
let us know it might take a bit to reset if it does not reset I would disconnect the battery to try to reset.
Old Jan 20, 2016 | 10:59 AM
krackenvette
Worked
Old Jan 20, 2016 | 11:03 AM
WVZR-1's Avatar
WVZR-1
I would doubt the CTSY fuse was a fix but then it is "fixed" (assumed). I'd think that while you had the alternator off (with battery disconnected) the CCM cycled and reset. The CTSY I'd think coincidental. Time will tell!!
Old Jan 20, 2016 | 11:13 AM
krackenvette
True, in regards to disconnecting battery.
Blown fuse is strange though.
I loaded the car too with defroster on, rear defrost and lights in gear. Didnt go below 14.1 after sitti ng for about 5 minutes. My 396LT1 does idld a little higher at 850.
Old Jan 20, 2016 | 11:17 AM
antfarmer2's Avatar
antfarmer2
Worked
good job I like cheap easy fixes.
To SYS code on dash... WT heck
