4+3 Overdrive
Old Aug 30, 2002 | 06:20 PM
Crazy Canuck's Avatar
Crazy Canuck
Default 4+3 Overdrive
Is it possible to have the ECM programmed to start the car with the OD in the off position? I find it very annoying when the car decides to shift on it's own, and it usually does it at the most inopportune time. :cuss
If the computer cannot be programmed, can the OD be bypassed in a way that will not interfere with the ECM? I would rather not set off any trouble codes, and I would still like to have a functioning OD light. Has anyone modified their car to solve this problem, and if so, how did you do it?
Old Aug 30, 2002 | 06:43 PM
ZylaRace's Avatar
ZylaRace
Default Re: 4+3 Overdrive (Crazy Canuck)
I'm sure it is, possible. This would take a code hack. Unless you find someone who did it already, it would take a fair amount of time.
Best approach would be to set the OD "ON" temp very (MAX) high. This should be quick. (No hack needed)
The 86 is wired a little different. I forget if the switch is tied to the OD light or not.
Post this in the Tune N Scan forum
Old Aug 30, 2002 | 07:08 PM
scorp508's Avatar
scorp508
Not yet. This is something nobody has ever been able to decipher where it is stored in the ECM's program.
Old Aug 30, 2002 | 08:30 PM
FlyboyZR1's Avatar
FlyboyZR1
Just press the button on top of your shifter before driving. :)
Old Aug 30, 2002 | 10:36 PM
jfb's Avatar
jfb
It is so automatic anymore, I don't even remember if I pushed the OD button when I start my 87. BTW Crazy Cannuck is redundant!!! :D :lol:
Old Sep 1, 2002 | 12:30 AM
Red88Vette's Avatar
Red88Vette
I just joined this forum. This place seems to have the most action!!!
I just bought my Vette last year. I may have an answer to your Overdrive problem. See my website. http://home.attbi.com/~rleickhorst
Old Sep 1, 2002 | 12:37 AM
scorp508's Avatar
scorp508
Hold on here. Am I reading this right? You found where it is stored in the ECM and now have it defaulting to off?
Old Sep 1, 2002 | 01:51 AM
Red88Vette's Avatar
Red88Vette
Default Re: (scorp508)
Yes, but it is not in the tables. It is in the actual code.
It should be similar for other type 32 bin files.
Send me your bin file and I will take a look.
Old Sep 1, 2002 | 01:55 AM
scorp508's Avatar
scorp508
I knew it was hardcoded, but nobody seemed to be able to find it. I'll email you my $32b BIN if you feel like playing. :D
Old Sep 1, 2002 | 02:07 AM
JonM's Avatar
JonM
Sounds like a stupid GM improvment. My 84 OD (upgrade without TV) works only with the switch. Its more of just an on/off button next to the window button. I'm going to have to trace the wires see where they go.
To 4+3 Overdrive
