check my diagnosis:opti spark
good friend of mine has a 93 corvette, lt1 6 speed. beautiful car.
he was out driving, ran flawlessly.
got home, and it died in the driveway. has not restarted since.
the original optispark died a few years ago, and was replaced with an MSD unit. new plugs, wires, water pump, etc at that time.
my guess was ignition module. replaced that. no dice. car still doesn't run.
fuel pressure is within spec.
the coil will shock the crap out of you if you touch it while cranking the car (I'm talking the lead to the coil wire. did this by accident, but it tells me the coil is getting signal to fire.)
injectors click when cranking (verified through mechanics stethoscope).
no fire at the plugs.
so, that leads me to believe its either a bad coil wire, or the rotor has gone.
any other ideas I'm missing? any tests I should run? I'm going back over there tomorrow night to double check things with my multi meter since I didn't have it last time. and reinstall the EBCM on his z06.
my recommndation is to search high and low for an oem ac delco (not acdelco remanufactured in china) unit and then vent it.
after venting it (with 95-96 harness) they become 100% reliable.
If your coil is sparking the Opti part of the distributor is working and so is the coil. If you have NO spark at the plugs the problem is in the coil wire to the distributor, the cap or rotor, or possibly the plugs/wires but that is unlikely as they would have to fail all at once.
I would confirm the coil wire is attached to the distributor and if so the I suspect a rotor failure inside the cap. You may just need and cap and rotor the rest of the distributor from what you have said is likely fine.
Will confirm tach signal, and check spark at other end of coil wire.
also the coil and spark control module usually dont fail. its usually always the optispArk - unless the optispark has been sealed up and a custom vent added. then it becomes 100% reliable. unless the vent system breaks down and water intrusion occurs.
the optical sensor is usually the issue. my test will confirm that.
Live well,
SJW
agreed. is it an intermittent problem?
need to take it apart and test it key on with coil wire attached to it and a single wire with a spark plug (grounded of course).
spin the shaft and see if sparks shoot out of it.
if it does then its good
also add weephole mod to waterpump while you are in there
Dig in, at this point no more testing is needed. You have spark at the end of the coil wire. The cap and rotor are not doing their job. Remove and inspect.
