My Vette bible doesn't shed light on a RPO # question i have - perhaps somebody has the answer(s)...
Is a 95 Z07 - owner sent me the codes - it includes UJ6 ( but not the WY5).
Reading here that the runflat was not avail. on 94 Z07 models - was avail. on 95 Z07's ?
Can it be disabled without causing error codes ?
Also includes several #'s i can't decode ...
AK5 - BGR - IL3 - J55 - KG9 - ML9 - BC/CC - U75 - VM3 - V73 - XAU - YAUWA -
C68 - DL5 - D18 - FE7 - NA5 - NK4 - QA1 - R7A - UX0 - LAY - ISB - 19I - 53U -
U9804 - GM3 -
If anybody knows a code or two - pls post your wisdom .
Thanks :seeya
