I have a 86 coupe with cast iron heads. I am just about to start a cam, lifters, springs, RR, and push rod install. I am installing 1.6 and 1.5 combo rockers. In the instructions with the rockers it says, "I should remove the heads for machine work to clear the new pushrods." I am not installing a high lift cam. All the parts are from Comp Cam. I never read anything about the head work until I opened the RR.
Has anyone had trouble with installing RR on a iron head vette? Should I do the machine work to be safe? If I have to pull the heads I might as well buy a better set. My goal wasn't to buy heads right now but; I don't want to put much money or time into the iron heads.
Any help would be appreciated.....
you really should use Screw in studs. you also need to check the Push rods for clearance. using 1.6 ratio rockers. typically you need to bore out the push rod passage holes on the iron heads. you should always check your rocker tip to valve stem center. especially using, new springs, cam? and 1.6 rockers. you NEVER just bolt in parts.
I have read many articles installing RR on an iron head vette. I never read about a pushrod clearance issue. I know if you install an aggressive cam and springs you will need screw in studs. I am not.
you may read a lil more. This is a standard boring Out the slots for the Push rods. To allow more clearance using 1.6 ratio's
then installing PR guide plates. Also needing Screw in studs.
you did not mention what springs you are using. Weather or not you will need to cut the pockets for larger springs. And reduce the stem for performance VG seals.
From: Las Vegas - Just stop perpetuating myths please.
Your wording has us a little confuse rrt. U say now u have a "kit" for your bottom end? Or do u mean u bought a kit for your top end that should work well with your stock bottom end?
Yes please list your parts and what your trying to do. We cant tell whether u have new springs for your new cam or not. Sometimes u need to enlarge the spring pockets for the new wider springs and that would require machine work also. BTW i feel u should change vlv springs every time u change the cam.
Vendors sell a tool to enlarge the push-rod slots in the head for 1.6 rocker arms. I think thats what the Admiral has in his picture and its normally called a "Lewis" tool. U need this because the 1.6 rockers move the p-rod in closer to the head and the stock slots are not long enough. Now if this slot is done right the slot will act as a guide plate and u wont need a guide plate or self-aligning rocker arms. Be careful though as some shops just hog out the slots expecting u to use guide plates - the shop just drilled mine out leaving huge holes because they knew i had guide plates.
I am not going that aggressive. The springs are stock. The cam's lobe is 114.
The slot fitment is least of worries atm, higher ratio rockers are more aggressive! I pulled a set of 84 iron heads studs out with exactly .480 lift, stock springs & 1.5 rockers, so I pinned them and they started to bend after that.
edit: to be clear those were 84 corvette iron heads used on a 355 in another car.
I am starting over. Maybe I should start a new thread?? I want to buy a cam, heads, and rockers that will work with a stock bottom end. I was even thinking of a retro fit roller cam. I have an early 86 block. I am not sure what is too big of a cam for my bottom end?
Okay my experience isn't with an 86 vette with cast iron heads but I did install a relatively high lift cam in an 86 cast iron head 350 out of an 86 Caprice Highway Patrol car which is probably the same thing.
On cast iron heads, where the push rod passes through, its a narrow slot...this is what locates / guides the push rod it doesn't use guide plates and it doesn't use self aligning rockers. the easy way to check is just rotate the engine by hand and see if there is any interference between the pushrod and the end of the slot...I'm willing to bet that with a relatively mild cam, that even with 1.6 rockers there won't be any interference. If there is, just relieve the end of the slot with a dremel tool or even a round hand file for that matter. It's important not to overthink these things, try the five dollar solution before trying the $1,500 solution, i.e buying and installing new heads.
Well if u want a whole top-end package u should provide your block and head casting numbers along with the stamped numbers on the pad in front of the passenger side vlv cover. The block cast number is in the rear behind the drivers side head and the head cast number is under the vlv cover 'bout the middle of the head. This will help identify a 2 bolt or 4 bolt block with cast or forged crankshaft. And most important what compression ratio u may have now and what it will change to with new parts.
Also u may want to start a new this. Well the sbc is the most popular and economical engine to modify. I suggest u shop for the economical/entry level parts for your first effort with this.
