Which size AFR Heads should I get?
Old Sep 1, 2002 | 02:02 PM
Bluevette85's Avatar
Bluevette85
Default Which size AFR Heads should I get?
I am leaning toward AFR 190cc heads to replace my iron heads. They come with two combustion chamber sizes: 68 and 74. I believe I have 76cc now. Getting the 68cc with increase my compression ratio to about 9.7 from 9.0 now. Questions:
1. 68cc or 74cc
2. What's different with their L98 heads compared to straight heads?
3. Where to buy?
[Modified by Bluevette85, 1:03 PM 9/1/2002]
Old Sep 1, 2002 | 03:24 PM
AquaMetallic94LT1's Avatar
AquaMetallic94LT1
Default Re: Which size AFR Heads should I get? (Bluevette85)
Get the 180 cc heads. The flow differences between the 180 and 190 are not much. The smaller intake runner will give better throttle response.
Old Sep 1, 2002 | 06:29 PM
87Beast's Avatar
87Beast
Default Re: Which size AFR Heads should I get? (AquaMetallic94LT1)
I'm using the 190's 68cc and custom chambered by AFR for 58cc which is the stock size for 87 heads. Not sure about the size for your 85 (I thought it might be 58cc but not sure). But I'm satisfied with these heads :yesnod:
Old Sep 1, 2002 | 08:09 PM
CORKVETTE1's Avatar
CORKVETTE1
Cruise-In IV Veteran
Cruise-In V Veteran
try to get a true 10.5 comp with the heads they might not help you much unless you attack the rest of the intake system
Old Sep 1, 2002 | 08:39 PM
Bluevette85
Default Re: Which size AFR Heads should I get? (CORKVETTE1)
I will probably get a superram and headers also.
Old Sep 1, 2002 | 08:48 PM
CORKVETTE1's Avatar
CORKVETTE1
Cruise-In V Veteran
add a cam and you are done :D
Old Sep 1, 2002 | 09:17 PM
vader86's Avatar
vader86
190s with the 68cc chamber, just keep the compression below 11 and youll be fine
L98s have a specific angle to the plug, this is what youll want for proper header fitment anyway.
I would buy them directly from AFR. airflowresearch.com
To Which size AFR Heads should I get?
