'84 tps
with the above 100%. IME, the actual min setting/voltage doesn't matter that much. As long at it's AROUND .5v, it's fine. I laugh when folks say you have to "set it to .525v". .525. WTF.
What the TPS supplies the ECM that is meaningful, is throttle position change, and rate of change and that is what's necessary for the ECM to supply the correct "pump shot" for enrichment during accel and enleament/fuel cut during decel.
An interesting thing to play with, is w/the engine running at idle, manually move the TPS open slowly, while throttle stay closed. What happens? Nothing. You may get a little surging of the inj spray pattern if you move the TPS too fast, but you can move it all the way to "WOT" and the engine should continue to idle mostly normally. Mine did, in the past. Now, do the same experiment again, but move the TPS fast. What happens? Injectors DUMP fuel for a brief moment, as you stroke the TPS. The TPS, during this "testing" should work very similarly to an accelerator pump in a carb.
