soft bakes
Old Sep 1, 2002 | 11:16 PM
sweet88's Avatar
sweet88
Cruising
Default soft bakes
I recently installed some inexpensive front brake pads on my '88. Since then the pedal is soft and i wonder if i will stop sometimes....The salesman assured me the cheaper pads would work as well put not last as long...any thoughts?
Thx
Old Sep 1, 2002 | 11:45 PM
ZBRA's Avatar
ZBRA
Default Re: soft bakes (sweet88)
Did you open the hydraulic system while you were changing pads?
Go to Auto Zone and buy a set of the $28 Performance Friction pads.
bogus's Avatar
bogus
uh... you may need to leave them in the oven a bit longer.
:jester
the pads are more than likely junk... or there is a bigger problem in the system...
Old Sep 2, 2002 | 12:39 AM
vader86's Avatar
vader86
Did you bleed the system, is the fluid good (not black).
Also, buy you some Performance Friction Pads.
To soft bakes
