Holley Adjustable Fuel Injection Regulator
Old Sep 2, 2002 | 12:13 AM
VetteWave's Avatar
VetteWave
Default Holley Adjustable Fuel Injection Regulator
I'm moving to 24lb injectors and need a adjustable fuel regulator. Is this a good part before I order it?
http://store.summitracing.com/partdetail.asp?part=21811
Old Sep 2, 2002 | 12:40 AM
85vet's Avatar
85vet
Cruise-In V Veteran
Default Re: Holley Adjustable Fuel Injection Regulator (VetteWave)
I ordered one about 4 months ago. Put it on the car and it would not maintain the pressure. It adjusted so much, you could shut off the fuel completely.
The maintaining of pressure problem consisted of:
I would set pressure at WOT (45lbs) and then the pressure at idle was tooo low. I could not find a happy medium and threw it away. :mad
Old Sep 2, 2002 | 12:55 AM
VetteWave's Avatar
VetteWave
Default Re: Holley Adjustable Fuel Injection Regulator (85vet)
So what is the best one out there?
Old Sep 2, 2002 | 12:56 AM
scorp508's Avatar
scorp508
I was about to say Holley IS the best one out there. Honestly that is the first time I've heard of one not working well.
Old Sep 2, 2002 | 02:28 AM
h rocks's Avatar
h rocks
Default Re: (scorp508)
Have run a *@#&tload of them on two different TPI cars, and hands down, the Holley was the best.
Old Sep 2, 2002 | 08:49 AM
VetteWave's Avatar
VetteWave
Maybe this one was defective. I will probably go ahead and get this one.
Old Sep 2, 2002 | 11:48 AM
Corvette0096's Avatar
Corvette0096
That one is the best one iI have seen so far. Stay away from a BBK they are junk. :yesnod:
Old Sep 2, 2002 | 01:04 PM
1MoorTym's Avatar
1MoorTym
I bought the Holley and after comparing the parts to a stock regulator I decided not to use it. The srping that it comes with looks and feels very wimpy compared to that stock piece and the plunger assembly is not tapered like the stock piece to fit in the regulator housing. Holley claims they do not make one for the Corvette although I know many on the forum are using them.
I bought the TPIS billet unit. Have not installed it yet, but much like several others, it uses the stock internals and just replaces the cap.
Old Sep 2, 2002 | 01:15 PM
VetteWave's Avatar
VetteWave
Default Re: Holley Adjustable Fuel Injection Regulator (1MoorTym)
Looks like TPIS makes one for the 92-96 LT1 engines, but not one for the L98. Anyone got any other suggestions?
Old Sep 2, 2002 | 01:51 PM
STL94LT1's Avatar
STL94LT1
TPIS makes an AFPR for the L98, part # 100-002, $89.
I am running a TPIS AFPR on my LT1 and it works great.
Also, you need a fuel pressure guage to tune the AFPR.
[Modified by STL94LT1, 5:53 PM 9/2/2002]
Old Sep 2, 2002 | 01:59 PM
Mr. Magoo's Avatar
Mr. Magoo
From: Damn taxes! Pimpin' Ain't Easy in Massachusetts
2018 C4 of Year Finalist
St. Jude Donor '03-'04-'08-'09
I'm using a T.P.I.S on my '86 Vette and it works fine. :)
1MoorTym's Avatar
1MoorTym
Default Re: Holley Adjustable Fuel Injection Regulator (STL94LT1)
TPIS makes an AFPR for the L98, part # 100-002, $89.[Modified by STL94LT1, 5:53 PM 9/2/2002]
Thats the part. Their older catalogs did not list it for 85-91 vettes because the printer screwed it up. The new 2003 catalog has it listed properly.
It also comes with the gaskets and security torx bit to install.
Old Sep 2, 2002 | 06:43 PM
VetteWave's Avatar
VetteWave
Should I get it from TPIS, or somewhere else. Jegs has it, but for the same prices as TPIS. Also, where should I get the guage to measure it? I want one that doesn't stay on the car. TIA
Old Sep 2, 2002 | 06:57 PM
MrNuke's Avatar
MrNuke
Default Re: Holley Adjustable Fuel Injection Regulator (Mr. Magoo)
Ditto.. :cheers:
Old Sep 2, 2002 | 07:13 PM
VetteWave's Avatar
VetteWave
Default Re: Holley Adjustable Fuel Injection Regulator (MrNuke)
What pressure are you guys running at?
Old Sep 2, 2002 | 09:21 PM
85vet's Avatar
85vet
Cruise-In V Veteran
I ended up buying the fuel regulator from Lingenfelter. Theirs included new innards and I did not have to use my old one. Their price was only $71.
Check it out:
http://www.lingenfelter.com/lingenfe...=17&pf%5Fid=69
Old Sep 2, 2002 | 09:57 PM
MrNuke's Avatar
MrNuke
I have mine set at 40=42psi Idle, 48-50psi WOT..
Only 2 turns from the lowest possible setting.
To Holley Adjustable Fuel Injection Regulator
Old Sep 2, 2002 | 09:59 PM
VetteWave's Avatar
VetteWave
Are there two settings on the adjustable fuel regulator? Never seen or used one.
Old Sep 2, 2002 | 10:29 PM
87Beast's Avatar
87Beast
I just picked up FMS 24# and the Holley AFPR last week, so I should know how it'll do tomorrow after I finish polishing one of my runners. But from a topic I posted (and a few others) the Holley seems to be the best AFPR, and you don't need a wrench to adjust.
Old Sep 2, 2002 | 10:48 PM
6spd89's Avatar
6spd89
Cruise-In II Veteran
Default Re: Holley Adjustable Fuel Injection Regulator (87Beast)
Can you make your own regulator??? Welding a nut on the cap
and using a allen screw to adjust up or down on the pressure.
Maybe someone else has done this??
Matt :confused:
