Rebuilt Engine - Missfires under load HELP!!!
Old Sep 2, 2002 | 11:26 AM
RED92LT1's Avatar
RED92LT1
Default Rebuilt Engine - Missfires under load HELP!!!
I did a favor for my brother in law by rebuilding the engine in his 67 Camaro. I was about ready to give the car back to him but I decided to test run the car to make sure the car performed as it should.
The problem I am having is at idle I can feel an irregular exhaust pulse in both exhaust pipes. It appears that it is maybe one cylinder because one pulse is stronger then the others. This is a dual exhaust without any cross over.
If I rev the engine to around 2200 to 3000 RPM I can hear it starting to break up slightly. When I road tested the car at part throttle it begins to break up and has no power. Sometimes this condition is worse then others, and on occasion it will pull hard with an occasional hiccup.
Everything is either new or reconditioned in the engine except Valve Springs. All parts are brand name ... no generic parts were used.
Here's what I have done so far:
-Tried a different distributor (new points, vacuum advance, condenser, cap, rotor and coil)
-Tired new different spark plugs
-Replaced plug wires with Accel 8mm solid core wires
-Checked timing numerous times
-Readjusted the hydraulic valve lifters to 1/3 turn preload (Engine running method)
-Cranking compression test around 170 psi all cylinders.
Engine components:
Comp Cam 268H-10 (Close to stock)
Comp Cams Lifters
Original Springs
Stock Q-Jet Carb (Rebuilt)
Stock Intake
Headers w/header mufflers
Power Glide
Stock type flat top pistons
Heads reconditioned with 3-angle valve job and valves hand lapped
I'm beginning to think the valves are not sealing properly and this is causing the poor performance.
ANY HELP or advice would be greatly appreciated!
Brian
