lean engine problems
Old Sep 2, 2002 | 12:27 PM
ICANTDR55's Avatar
ICANTDR55
Default lean engine problems
This is what I have; chevy 355 cid vortec engine. ported vortec heads, victor jr. single plain intake, headers(hooker),830 holley carb. with primary jets of 84 and secondary jets of 88. msd ignition set up. roller lunati cam;.242/252 @ .050 and .525/.540. set of AC/plugs 44 heat range. You can hear the engine leaning out while making a pass. when the plugs were checked after making a couple of passes, it was like we had fired up the engine ran it for about 3 min. and shut it down. plugs still very white. what could the problem be? :cry
Old Sep 2, 2002 | 11:24 PM
ICANTDR55's Avatar
ICANTDR55
Default Re: lean engine problems (ICANTDR55)
come on guy, surely someone can give some advice as to what might be the problem. Please help out. thanks
Old Sep 3, 2002 | 11:07 AM
lead foot 85 vet's Avatar
lead foot 85 vet
PURHAPS YOU WOULD GET SOME RESPONCES IF YOU POST THIS IN THE ENGINE MODS SECTION.
To lean engine problems
