Question regarding the pass door window fix...
Old Sep 2, 2002 | 12:58 PM
Slow LX's Avatar
Slow LX
Default Question regarding the pass door window fix...
Well it seems the motors are good, but the pass side window has trouble getting lowered. When you try to lower the window the motor moves, but you have to physically push it down. :U
I want to take apart the door to fix it, but I want to hear a little about it first (hidden screws). Any tips would be greatly appreciated.
[Modified by Slow LX, 5:01 PM 9/2/2002]
Old Sep 2, 2002 | 01:03 PM
Blue 92's Avatar
Blue 92
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
Default Re: Question regarding the pass door window fix... (Slow LX)
Try this article.
http://www.corvettemagazine.com/2001...ndow/win-1.ASP
It's about replacing the weather stripping but tells you how to pull the door panel.
Old Sep 2, 2002 | 01:11 PM
BLUE ONE's Avatar
BLUE ONE
Default Re: Question regarding the pass door window fix... (Blue 92)
The hardest part is removing the door panel.
Once its off the rest is self explanitory just by looking at the mounting points
:cheers:
To Question regarding the pass door window fix...
