underdrive pulley fitment
Old Sep 2, 2002 | 01:23 PM
BLUE ONE's Avatar
BLUE ONE
Default underdrive pulley fitment
Can someone tell me if it is possible to remove the crank pulley from the engine compartment without taking off the water pump on a 1990 Vette ? :confused: :confused:
If so what do you do ? looks to tight to me. :smash:
:cheers:
Old Sep 2, 2002 | 02:29 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: underdrive pulley fitment (BLUE ONE)
You can do it but you need to remove the "frisbee" and the water pump pulley to clear the cross-member with the crank pulley.
Old Sep 2, 2002 | 06:30 PM
BLUE ONE's Avatar
BLUE ONE
Default Re: underdrive pulley fitment (65Z01)
thanks for that, the freezbee has long gone after reading your comments last year, i was going to fit the crank and water pump pulleys anyway so it all looks good. i just thought it looked a bit tight even with the water pump pulley out.
:cheers:
To underdrive pulley fitment
