clutch master fluid
Old Mar 4, 2016 | 03:24 PM
tjgator's Avatar
tjgator
4th Gear
Default clutch master fluid
Hello everyone! My name is tj and I guess you could say I'm a long time reader here and now a first time poster. Unable to find an ac delco clutch master cylinder for my 95 I got a wagner. My current one is leaking and making a mess. I want to use the proper fluid so my new one doesn't start leaking. My local chevy man says no gm#12345347 available use DOT 4. Others say DOT 4 for brakes and DOT 3 for clutch. I was hoping to hear what you guys use. Any input would be greatly appreciated.
Old Mar 4, 2016 | 03:52 PM
TorchTarga94's Avatar
TorchTarga94
Either is fine. You should consider returning the Wagner and getting the factory one rebuilt by this guy:
http://www.powertorquesystems.com/Co...eCorePrgrm.htm
Old Mar 4, 2016 | 07:19 PM
c4cruiser's Avatar
c4cruiser
Luk has a good quality clutch master and you can get it at
Amazon Amazon
You could return the Wagner piece assuming it's under warranty but you may have to send the old one back in order to get a replacement. Check with the place you bought it from.
For clutch fluid, a good DOT3 brake fluid will work fine. I had used the Ford Motorcraft HD brake fluid in my '87 and never had a problem. This same fluid can be used for frake fluid too. The wet boiling point of this fluid is at the high end of the DOT3 scale. It comes in 8 oz bottles so you don't have to buy a full quart container of something else and have a half-bottle just sitting.
Old Mar 5, 2016 | 01:26 AM
tjgator's Avatar
tjgator
4th Gear
I don't have the original. The one on it now is NAPA brand I'm pretty sure. I thought I was getting an ac delco from Jeggs but was soon told backordered then unavailable. Im not sure who Luk is but I'll figure that part out. I'll gladly return the Wagner . Thanks guys!!
Old Mar 5, 2016 | 08:24 AM
grandspt's Avatar
grandspt
I have been using DOT5 silicone brake fluid in my clutch master cylinder for 6 years on my Vette with no problems.
I had a slave cylinder go bad and when I looked in the bore it had quite a bit of rust. The rust was probably from the hydroscopic nature of regular brake fluid and my car sits in the garage during the winter. I replaced the slave and master at the same time then used DOT5. I have not had any issues with my clutch since.
Old Mar 5, 2016 | 08:54 AM
c4cruiser's Avatar
c4cruiser
Luk is a company that makes clutch assemblies. I had checked various places for AC Delco clutch cylinders and never found one. I would have thought AC Delco would have something like that.
If the clutch master is a NAPA unit, that should be a decent part. If you have a local NAPA store, it can't hurt to check with them to see if they have one in stock for a replacement.
Old Mar 6, 2016 | 05:34 PM
94corvetteC4's Avatar
94corvetteC4
I went with a napa clutch master cylinder and slave cylinder with dot 3 synthetic on my 94 six months ago. Clutch has been fine so far.
Old Mar 9, 2016 | 05:52 PM
ovrebo1's Avatar
ovrebo1
What makes his worth that much over one that costs x3 less on ebay with no core charge? I'm in the market for one, so that's a serious question, I'm not trying to stir things up.
Old Mar 9, 2016 | 09:05 PM
mtwoolford's Avatar
mtwoolford
And I thought I was the only, lonely, one singing the praises of DOT 5 silicon brake fluid; true you can' use it in a ABS brake system (too viscous for the little ABS solenoid valves), but for anything else hydraulic, i.e. non ABS brakes and hydraulic clutches, its the only way to go; and it doesn't harm paint...can't say about DOT 3 or DOT 4
Old Mar 9, 2016 | 09:33 PM
grandspt's Avatar
grandspt
Actually I thought I would get a bunch of nay sayers by using DOT5 in my clutch master cylinder, glad to hear someone else has been using it. I used to put DOT5 in my 1983 Z28 (Non ABS) that I raced and it sat for months in the winter outside. The rear disc brakes never worked when I used hydroscopic fluid. But DOT 5 cured the problem.
I wish it was compatible with ABS I would use it in my brake system hydraulics too.
Old Mar 10, 2016 | 03:27 PM
TorchTarga94
The cast units don't last nearly as long as the original stamped steal type cylinders (both master and slave). They are made or refurbished in a foreign country with bottom dollar parts and a quick coat of paint. Sometimes the inner bore isn't perfectly smooth which leads to premature failure of the seals. This leads to air/dirt in the system, and you know the rest...
Jim Jandik @ power torque systems bought all of the remaining NOS clutch components some time ago and regularly rebuilds these systems. He knows everything there is about the C4 clutch hydraulics and uses quality sourced parts. If you ever have a problem, you just shoot him an email and he will get right back with you and is more than happy to check anything out. This is what makes it worth it to me.
Back in 2012 when I was doing a lot of PM I replaced both the master and slave with cast Wagner units. They worked fine, but I could immediately tell a difference in the feel of the clutch. They almost had a rough feel, and I also noticed a "squeak" type noise when depressing the clutch pedal with the engine off. Luckily I kept the original stamped steal units, and sent them off to Jim. Can't remember the cost, but it was well worth it. I brought the Wagner units back to the parts store and got my money back.
Point is, do what you want. But the Clutch and Transmission on these cars aren't necessarily cheap to repair. I try to use the best quality parts when it comes to clutch/trans (Same with LT Ignition Componenets ). His are arguably the best in my opinion.
Old Mar 10, 2016 | 06:31 PM
ovrebo1's Avatar
ovrebo1
I appreciate the response. I think for the $100 savings I'll take a chance on the ebay ones. On the topic of cheap parts I feel like everyone said to stay away from the Autozone Opti's and that's what I installed last go around with the addition of vacuum vents and the car has never ran better. Its a mixed bag with cheap parts.
To clutch master fluid
