Code 32: Need help!
Old Sep 3, 2002 | 08:49 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Default Code 32: Need help!
Where is the EGR temp sensor located on a 1992 LT-1 engine? I'm getting Code 32 and I think mine may be faulty. Thanks!
Old Sep 3, 2002 | 09:06 AM
vader86's Avatar
vader86
Default Re: Code 32: Need help! (onedef92)
if youre gettin code 32, its the solenoid/switch
or you can ignore the code, its nothing to worry about
Old Sep 3, 2002 | 09:36 AM
onedef92's Avatar
onedef92
Default Re: Code 32: Need help! (vader86)
OK, Vader86. The EGR solenoid is located on the passenger side of the engine near the rear of the intake, right?
Old Sep 4, 2002 | 05:11 AM
Ron78Z&66Vette's Avatar
Ron78Z&66Vette
Not always :) .
Old Sep 4, 2002 | 12:02 PM
onedef92's Avatar
onedef92
Default Re: Code 32: Need help! (Ron78Z&85Vette)
True dat. In some cases, it can cause cascade system malfunction, or retarded spark, emissions test failure and other dreaded ills..
Old Sep 4, 2002 | 12:04 PM
Nathan Plemons's Avatar
Nathan Plemons
The EGR valve is located on the back of your intake, driver's side. Follow the vacuum line off of that to the control solenoid.
To Code 32: Need help!
