Spark plug fouling advice?
Old Mar 10, 2016 | 07:48 PM
DanielRicany's Avatar
DanielRicany
Default Spark plug fouling advice?
Hello everyone. I had to get colder spark plugs so I could use nitrous for my 85 Corvette. I'm having a bit of an inconvenience here. My vette primarily stays in the garage so typically I have to start it up for a few seconds frequently to move in and out of the garage when I need to do something in there. So my plugs are fouling from too many cold starts without letting it reach operating temperature.
Since the ECM commands a richer mixture during cold starts, if I increase ignition timing for cold starts in the tune, will that help solve my fouling issue?
Old Mar 11, 2016 | 03:01 AM
cv67's Avatar
cv67
St. Jude Donor '05
Shouldnt make your plugs foul you got something more going on
On your header Q cut the collectors off and get some new ones welded on or replace the headers leaks and EFI dont play well
Old Mar 11, 2016 | 03:20 AM
BOOT77's Avatar
BOOT77
What type of O2 are you using? I'll assume longtube headers, I've herd you should use a heated O2 with LT headers and that also should help on cold starts.
Old Mar 11, 2016 | 07:53 AM
DanielRicany
Theyre fouling because they are on the edge of being the coldest plug I can use. When it idles all the time when cold without ever getting the cylinders hot, they foul.
Old Mar 11, 2016 | 08:52 AM
1984Z51auto's Avatar
1984Z51auto
How about making a pass with the nitrous on when they get iffy? Won't that clear the plugs?
Old Mar 11, 2016 | 09:17 AM
DanielRicany
I doubt it honestly.
Old Mar 11, 2016 | 09:22 AM
antfarmer2's Avatar
antfarmer2
I see two choices push it in and out or drive it.
Old Mar 11, 2016 | 09:37 AM
9T3VETTE's Avatar
9T3VETTE
Agreed. Plug temperatures have to reach 500degC in order for carbon to naturally burn away which is called the "self clean" temp. Even with a few minutes of idling they should clean.
How cold of a plug do you have in it?
Old Mar 11, 2016 | 09:53 AM
DanielRicany
NGK 7 heat range
Yeah and if it's a hot idle I could idle all day no problem. But it's rich when it's cold and it never a gets enough time to warm up when I pull it in and out.
Old Mar 11, 2016 | 10:19 AM
383vett's Avatar
383vett
I'm running NGK 7s in my Vette. I have no fouling. Maybe as suggested, push the car out and push it back. I don't like to cold start any of my cars without letting them warm up. A lot of creatures are left in the cylinders after a cold start and shutoff.
Old Mar 11, 2016 | 10:35 AM
DanielRicany
Maybe I'll invest in a winch
Old Mar 11, 2016 | 10:48 AM
antfarmer2's Avatar
antfarmer2
harbor freight has cheap ones that will work.
Old Mar 11, 2016 | 11:52 AM
cv67's Avatar
cv67
St. Jude Donor '05
Maybe I'll invest in a witch
Give me half Eddie!
To Spark plug fouling advice?
