Transmission fluid
Old Mar 11, 2016 | 11:04 AM
Zhee'sVette's Avatar
Zhee'sVette
Navigator
Default Transmission fluid
can anyone tell me how to check the transmission fluid in my 1985 c4. I bought it in aug 2014. I drove it a little to familiarize myself with it. I saw a small leak between june - oct 2015. It seems to have gotten worse. The battery died shortly after so I need to get that resolved and begin the work to restore the few things that I know need addressing, but want to make sure there's enough fluid in the tranny to move it.
Old Mar 11, 2016 | 11:26 AM
antfarmer2's Avatar
antfarmer2
Auto in park running check the stick manual pull the plug should dribble out both on level surface.
Old Mar 11, 2016 | 12:44 PM
s carter's Avatar
s carter
the only thing that I will add to Ant Farmers advise is if a Manual trans is Gear oil in the main trans (the T-10 unit the front trans) ATF in the O-D unit the one more rear, be warned the O-D units tend to smell like gear oil if not serviced regularly so don't be fooled. So if your O-D has black Stinky oil it needs a full service
Old Mar 11, 2016 | 02:23 PM
aklim's Avatar
aklim
I'd make sure it is at operating temp before I do that if it is auto.
Old Mar 11, 2016 | 07:09 PM
Zhee'sVette
Navigator
thanks
Old Mar 11, 2016 | 07:23 PM
Zhee'sVette
Navigator
it's an automatic. thanks
Old Mar 11, 2016 | 07:25 PM
Zhee'sVette
Navigator
do you mean let it run a while then check it? thanks
Old Mar 11, 2016 | 07:31 PM
antfarmer2's Avatar
antfarmer2
Yes
Old Mar 11, 2016 | 07:42 PM
WW7's Avatar
WW7
It's better if the car is at full running temperture, check it when you get home after running around......WW
Old Mar 11, 2016 | 07:48 PM
aklim's Avatar
aklim
Go for a 10 mile drive and check then. Make sure you are on level ground and check. I want fluid moved around, hot and see if the fluid is in good condition with nothing swirling around.
To Transmission fluid
