The weather has been pretty nice here in NY over the last few days, so I decided to get my 87 out of winter storage. Happily, it started right up without a hiccup... but the brake pedal went right to the floor.
Master cylinder reservoir was empty. *sigh*.
I checked the master cylinder and all 4 wheels and there's no signs of leakage.
To be honest, I can't remember the last time I checked it, so it may have been low for a long time. Top it off, and now when I pump the brake with the car off, the pedal gets hard, then slowly goes down. Fluid in the reservoir is dark.
If I pump the pedal with the car running (or when I start the car with my foot on the pedal) as soon as it turns on, the pedal goes right to the floor.
Thoughts on where to start? Where could that fluid have gone?
If your 87 has ABS check the ABS module in the compartment behind the driver's seat and see if their are any leaks there.
Thanks. I'll take a look. Would ABS cause that soft pedal upon starting? The disappearance of the fluid?
Edit: Clean as a whistle in there, no leaks.
Originally Posted by antfarmer2
Master cylinder and brake booster
Master cylinder builds up pressure, and the brake booster let's out a hiss when I remove the vacuum hose, so there's pressure there too. My gut says both are fine.
This link would seem to imply that the pedal would get HARD not soft if the booster were shot.
Who said the booster was shot? If your not loosening fluid now it might just be. Going by the seals in the master. Hard to tell how or when you lost it since you never check it. If it did get into the booster it can eat things.
So, if you're right that the the master cylinder is leaking into the brake booster, what do I need to do to confirm that? There isn't a spec of fluid on the outside of the booster or the master cylinder.
Did you find fluid in the abs storage? Are you loosening fluid? Have you found any leaks now that you put fluid in?
I cannot see it from here.
Feel up by your pedal and your carpet too.
After my last post I took it for a ride around the block, in the hopes that something was seized up and might unsieze.
Half an hour later, there are a few drips on the driveway, and it appears to be coming from the joint where the booster and the master cylinder come together. So it looks like I need a master cylinder.
How (or do I need to) get whatever fluid I assume has leaked into the booster out? Could the booster have been damaged?
Boosters have rubber in them. Brake fluid is bad for it. It needs to come out. I would replace it if you confirm fluid inside. Inspect with flashlight thru vacuum line hole or the master cylinder when you remove that.
Brakes are not something to mess around with IMHO. Given the age of the booster and LIKELY contamination, replacement is the prudent thing to do.
Ok... I am prepared to order a new MC and booster.
Anyone have an opinion on the RAYBESTOS MC39621 master cylinder? I can get it for $112 at Rock auto.
Similarly, an OEM booster remanufactured by Durastop is $96-- a non-reman is $325, so unless there's a really compelling reason to spend an extra $229 on the part, I don't intend to do so.
I'd say that 90+% of the time one of the rubber seals on the Master Cylinder piston fails - so I wouldn't have issues going with a rebuilt Master Cylinder.
