How do you clear codes?
Old Sep 3, 2002 | 01:29 PM
champs_97's Avatar
champs_97
Default How do you clear codes?
Just wondering how you clear old codes.
Old Sep 3, 2002 | 02:08 PM
vader86's Avatar
vader86
Default Re: How do you clear codes? (champs_97)
disconnect the battery for about a minute and theyll clear
Old Sep 3, 2002 | 02:40 PM
Steel Blue 91's Avatar
Steel Blue 91
Default Re: How do you clear codes? (vader86)
Our pull the ECM fuse. That will do it also.
Old Sep 3, 2002 | 02:41 PM
Steel Blue 91
Or pull the ECM fuse. That will do it also.
Old Sep 3, 2002 | 07:26 PM
vetracer's Avatar
vetracer
Default Re: How do you clear codes? (Steel Blue 91)
Is one method better than the other? I know disconnecting your battery will cause the ECM to "unlearn" all of its stored parameters, which will temporarily affect performance. Will pulling the ECM fuse have the same effect? Sounds like yes would be the obvious answer, but I could be wrong.
Old Sep 3, 2002 | 07:30 PM
vader86's Avatar
vader86
Default Re: How do you clear codes? (vetracer)
Pulling the ECM fuse will have the same effect as disconnecting the battery. ECM will have to relearn.
Old Sep 3, 2002 | 07:35 PM
jefft84's Avatar
jefft84
Both methods work the same. However niether clears the code it just moves it to history unless a problem still exist then it will come back as a hard code turning the light on. Soft codes or history codes must be cleared with a scan tool.
Old Sep 3, 2002 | 07:58 PM
LaVidaLoca's Avatar
LaVidaLoca
Same result either way. EXCEPT disconnecting the battery also resets all the presets on your radio. :eek:
Old Sep 3, 2002 | 08:00 PM
robtx's Avatar
robtx
Default Re: How do you clear codes? (jefft84)
Autozone will clear it for FREE
Old Sep 3, 2002 | 08:13 PM
vert2go89's Avatar
vert2go89
Cruise-In I Veteran
Default Re: How do you clear codes? (robtx)
Just pull the ecm fuse that way you are not clearing radio and everything else.
To How do you clear codes?
