1994 steering column removal
Old Mar 14, 2016 | 08:26 PM
85autoxr's Avatar
85autoxr
Default 1994 steering column removal
I need to replace my steering column. anything hard abut this? nuts at firewall inside car, bolt at coupler in engine bay, 2 bolts holding column up...?????? un plugging wires at column base....???
Old Mar 14, 2016 | 08:30 PM
antfarmer2's Avatar
antfarmer2
Take the bolt out at the coupler not just loose.
Old Mar 17, 2016 | 07:55 PM
Purple92's Avatar
Purple92
I had to get my column rebuilt as the Previous owner seems to have used the wheel to pull himself up as he got out of the seat....
The only "hard part" of the job was the reinstall - where you really need two people to get the column installed. One person putting the column in the car - and another under the hood lining up the shaft and the steering rack input. Removal is more a matter of making sure everything (particularly wiring) is disconnected and out of the way as the column comes out....
Old Mar 30, 2016 | 07:26 AM
85autoxr's Avatar
85autoxr
Default steering column
ok am I missing something by firewall? all plugs disconnected bolt out of steering knuckle bolts out under dash holding column up flange at firewall unbolted cant pull column out.. something else need unbolted???
Old Mar 30, 2016 | 07:34 AM
antfarmer2's Avatar
antfarmer2
Might try a little penetrating oil where the pich bolt was and tap the grove with a wedge.
Old Mar 30, 2016 | 07:49 AM
WVZR-1's Avatar
WVZR-1
Is the car an AT or a MT? An AT car has the shift interlock cable attached at the column base. Do you have the interlock cable removed from the column? I've got a snapshot but on a different computer. Here's a good image that might help. Do you have an FSM?
The cable needs either removed from the top of column (in image) or at the column to firewall base. Maybe both. I've never removed a later C4 column in an AT car- never owned an AT.
http://www.wholesalegmpartsonline.co...riveLine=11463
If you've everything unbolted and the intermediate shaft pushed aside you might be able to give a good rap on the steering shaft towards the top.
Old Mar 30, 2016 | 05:09 PM
85autoxr's Avatar
85autoxr
sorry guys I got it out. had to remove gas pedal nuts toi get column out. ALLS GOOD SO FAR. replacement columns another story
Old Apr 17, 2016 | 11:14 AM
85autoxr's Avatar
85autoxr
anyone have a pic of six speed steering column wires plugged together??
Old Apr 17, 2016 | 11:33 AM
WVZR-1's Avatar
WVZR-1
There's only the SIR (yellow) at the base, 2 for the ignition switch (only fit one way), the dimmer switch, wiper and the directional switch. There's nothing to confuse you. Pretty damned straight forward. Cruise and VATS are hangers so there's no confusing them either.
Old Apr 17, 2016 | 11:49 AM
85autoxr's Avatar
85autoxr
well my son removed it and im putting it back together. that's why I was looking for a pic or 2..
Old Apr 17, 2016 | 11:53 AM
WVZR-1's Avatar
WVZR-1
They're both sides of the column and also top and bottom. They're not all encompassing for a single snapshot. If you have them hanging from under the dash now and the column isn't back in post a snapshot and all of them can be ID'd.
Do you have the FSM?
Old Apr 17, 2016 | 12:48 PM
WVZR-1's Avatar
WVZR-1
Not a snapshot but might help:
This is TYPICAL '90+ TOP is RH and the BOTTOM LH
Name:  '92+ column.png
Old Apr 17, 2016 | 02:58 PM
85autoxr's Avatar
85autoxr
Default vats
Attachment 47973209
can I bypass vats all togejhter??
Old Apr 17, 2016 | 03:48 PM
antfarmer2's Avatar
antfarmer2
Yes you can get a kit off ebay or just get the resistance off your key and buy that resistor.
To 1994 steering column removal
