Driver side rear is lower
Old Sep 3, 2002 | 04:45 PM
87Beast's Avatar
87Beast
Default Driver side rear is lower
Just noticed it a few days ago, I thought it might be the ground level but wherever I park the driver side rear is lower. Is there an easy way to fix!
"The Vette makes 'em wet" - TRUE LIES
Old Sep 3, 2002 | 04:59 PM
Alphatoto's Avatar
Alphatoto
Default Re: Driver side rear is lower (87Beast)
Last week I noticed the same on my '88. I Looked and noticed I had cracked my rear mono leaf. Bought replacement at VBP for $300. Took a couple of hours but did wonders for handling.
Old Sep 3, 2002 | 05:02 PM
J Z06's Avatar
J Z06
Default Re: Driver side rear is lower (casolino)
Springs can crack....but most of the c4's(if not all of them) are more "relaxed" on the drivers side. Crank the drivers side spring bolt if you'd like to even it out. That ought to do it.
65Z01's Avatar
65Z01
Cruise-In II Veteran
If your rear spring is Ok you can use the lowering bolts from MAD to even it up.
Old Sep 3, 2002 | 05:04 PM
87Beast's Avatar
87Beast
Was the crack obvious? Last time I saw my spring, it looked good, but I'll check again.
Or my car is telling me to go on a diet and no more beer :cheers:
[Modified by 87Beast, 1:07 PM 9/3/2002]
Old Sep 3, 2002 | 09:20 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Check the spring, but the "lean" came with the car!
Almost all do it and no one can give a satisfactory reason. They don't do it all the time either, which is really confusing :rolleyes:
Just drive and enjoy
:seeya
Old Sep 3, 2002 | 10:55 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Default Re: Driver side rear is lower (jackdaroofer)
They came that way from the fatory. GM did it so that car looks level when you factor in road crown. Easily adjusted with the rear bolts.
To Driver side rear is lower
