What a Dip Stick
Old Mar 18, 2016 | 11:47 AM
eutu1984's Avatar
eutu1984
2021 C4 of the Year - Modified Finalist
Default What a Dip Stick
I have oil leaking from my dip stick shouldn't there be a O-Ring or seal at the top or not and if so where to get one I have searched and only ones I can find are aftermarket universal types.
Old Mar 18, 2016 | 11:52 AM
ovrebo1's Avatar
ovrebo1
If you are referring to oil coming out of the tube, at the top, were you actually pull the dip stick out, then your PCV could be plugged or worse......
Old Mar 18, 2016 | 12:11 PM
WVZR-1's Avatar
WVZR-1
It does certainly seem that a more descriptive explanation of the problem is required. USER ID hints that it might be an '84. Is it or isn't it. If NOT what is it?
Old Mar 18, 2016 | 03:10 PM
eutu1984's Avatar
eutu1984
Sorry its a 90, PVC is good, I just need to know if there should be a rubber grommet or O ring at the end of the dip stick just under the T handle. the amount of oil is very small and there is no signs of blow by. there is just a small amount of oil that's annoying. I tried searching for a new one but the only new ones I could find was for an 84.
Old Mar 18, 2016 | 05:44 PM
96GS#007's Avatar
96GS#007
Yes, it should have an o-ring.
Old Mar 18, 2016 | 09:34 PM
esham's Avatar
esham
Are you sure? I just checked my 90 and 92. Neither has an o-ring.
Old Mar 18, 2016 | 09:42 PM
eutu1984's Avatar
eutu1984
for some reason I remember a grommet or o ring being there.
Old Mar 19, 2016 | 06:02 AM
Joe C's Avatar
Joe C
FWIW, my 85 DID NOT have any type of o-ring. in fact, my 85's FSM says to -
Clean tube and apply sealant #1052080 or equivalent, around tube 1/2" below bead. insert tube...
since this is a 90, the 90's FSM says -
Clean tube an apply sealant GM P/N 1052080, or equivalent, around tube 12.7mm (0.5 in.) below bead. Tube into cylinder block and rotate into position....
nowhere in either FSM, does it refer to any type of o-ring. when I re-assembled my 85's L98, I just used RTV - black, oil resistant type. same stuff I used on the china walls. the "bead" they refer to is a rolled bead on the tube itself that limits the depth the tube can be set into the block.
Old Mar 19, 2016 | 06:06 AM
eutu1984's Avatar
eutu1984
I was referring to the top of the dipstick where the t handle is and not the tube, thanks for the info from the FSM.
Old Mar 19, 2016 | 06:22 AM
Joe C's Avatar
Joe C
sorry, didn't pick up on that -
...at the top...
again, FWIW - just checked my 85's dipstick - no o-ring that I can see.
Old Mar 19, 2016 | 08:00 AM
WVZR-1's Avatar
WVZR-1
There's NOT an o-ring on any of the early GM dip-sticks for engine oil.
OP - I'd check the dip-stick for a part # to confirm first of all that it's original, correct and GM.
A '90 I would expect a 10108430 on the stick. Joe C can likely confirm that from his '90.
There's multiple possibilities that create issues like you mention. Depends on how bad the problem is. Does it actually "lift" the stick from the tube?
Old Mar 19, 2016 | 10:08 AM
Joe C's Avatar
Joe C
10108430 on my 90's dipstick, and no O-ring...
Old Mar 19, 2016 | 10:33 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
If you're pushing oil out the top of the dip stick tube, you have crank case pressure. What causes crank case pressure? Combustion gasses getting past the rings; blow by. Even if your PCV valve were non functional, normal crank case gasses should easily exit through the intake side of the PCV system, into the intake snorkle. You could check "both sides" of the PCV system to ensure that they aren't closed off w/carbon. Beyond that, it would be time for a leak down test.
Old Mar 19, 2016 | 11:27 AM
eutu1984's Avatar
eutu1984
Its a new 383 build and no other signs of blowby, infact the tube going from the TB to the passenger side valve cover is dry inside, I have a little over 500 miles on the build so I plan on doing a leak down test anyway. I just cant stand little bit of oil anywhere on a new build.
Old Mar 19, 2016 | 11:47 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
That's interesting. I don't blame you for not wanting oil on a new engine!
I don't know why you're getting oil up the DS tube, but not in the breather tube.
Old Mar 19, 2016 | 01:43 PM
eutu1984's Avatar
eutu1984
I just whent and removed the snorkle and looked through the TB with the throttle blades open and its bone dry inside. I was wondering if maybe I have to good a seal. I am not using gapless rings but if I remember correctly from about 30yrs ago if you ran the gapless rings you had to place a restrictor in your pvc line. I am running hypereutectic pistons with conventional rings and I don't ever remember hearing about having to run a restrictor with those.
Old Mar 21, 2016 | 09:45 PM
FOURSPEEDVETTE's Avatar
FOURSPEEDVETTE
I once put a dab of RTV silicone into the end of the dip stick handle on an old Firebird I had. It didn't have an o-ring and leaked oil out there a little. I let the silicone set up until it dried and installed it back on the car. It never leaked out again. The packed in silicone worked just fine to seal the dip stick into the tube.
Old Mar 22, 2016 | 02:52 AM
WVZR-1's Avatar
WVZR-1
Not done to a GM stick but a friend I believe sealed a dip-stick using an older umbrella style valve-stem seal jammed into the dip-stick handle.
Stop by a dealer/junk yard and check some later GM dip-sticks, the later use an o-ring and if you found a "fits the tube" maybe cut the stick and use the handle only.
OP - you didn't mention if the dip-stick is actually "lifted". If yes I believe you've issues.
Old Mar 22, 2016 | 05:50 AM
eutu1984's Avatar
eutu1984
The stick does not blow out, I got a spector chrome dipstick from autozone that has a grommet on the end of the stick, the chrome tube will not fit without modification, I don't like the end of the chrome stick so when I have a chance I will try and swap the end from the old stick or the grommet.
To What a Dip Stick
