Interior ground passenger side???
Old Mar 20, 2016 | 04:12 PM
fast.asleep's Avatar
fast.asleep
Default Interior ground passenger side???
I got around to adding a dashcam to the corvette. I'm using an add-a-fuse to take power from the radio fuse but can't find a ground! I took the hush panel off but everything is plastic!
Help!
Old Mar 20, 2016 | 04:17 PM
antfarmer2's Avatar
antfarmer2
Just pull the carpet back and attach to the side kick.
Old Mar 20, 2016 | 04:46 PM
WVZR-1's Avatar
WVZR-1
Help!
What year is this car? In all of the later '91+ cars there's circuit add capability wired into the car with blunt cut leads in the console. There's many other opportunities and locations also depending upon the year of the car.
Old Mar 20, 2016 | 05:08 PM
crowz's Avatar
crowz
Well you can use an add-a-fuse to take ground from the radio too if you want
I ran a wire to where the dash support brace meets the firewall under the dash pad on my 87.
Old Mar 20, 2016 | 06:49 PM
fast.asleep
Awesome. I saw the bolt as soon as I pulled the carpet back. Tested and working
Thanks all!!
Old Mar 20, 2016 | 06:54 PM
fast.asleep
I thought the add a fuse was always positive?
Old Mar 20, 2016 | 07:47 PM
antfarmer2's Avatar
antfarmer2
Thanks all!!
Old Mar 21, 2016 | 06:54 AM
crowz's Avatar
crowz
You can fuse positive or negative. Though positive is the norm. The only reason I mentioned using one is when people use them at all they don't want to cut wires. So that would allow for grounding without cutting the radios ground wire.
To Interior ground passenger side???
