Performance
Old Mar 21, 2016 | 02:57 PM
rennertristan's Avatar
rennertristan
Default Performance
I'm looking to upgrade my 1986 corvette. Right now it's complety stock and I want to get headers, cam, intake, chip, performance spark plugs, throttle body spacer, full exhaust and other things of that nature, unfortunately I just switch from jeeps to corvettes so I'm nit too good with these parts for this car. I want the vette to be loud at idle with the new cam and a lot faster. I'm not gonna spend more than 3,500 dollars. If someone could send me some links for some parts or hook me up with someoNE or a shop in the San Diego area that could help me that would be very much for apericated
Old Mar 21, 2016 | 03:27 PM
John A. Marker's Avatar
John A. Marker
Comments:
1) Standard spark plugs will work fine. Forget the hype on special plugs.
2) Throttle Body spacer a waste of money, no appreciable gains to be made.
4) How many miles on the block? Depending on mileage, you might want to consider a new short block.
3) You will have to research and consider replacing the plenum and runners to make some serious power....if you can find a use SuperRam or a MiniRam. If you can't go this route, then bigger runners, intake with larger ports and consider porting the plenum.
4) A good set of aftermarket heads.
5) New cam = new lifters and think about 1.6 roller rockers.
6) Need to find a set of CARB approved headers if there are any. I know that there were NONE for my 85.
7 You are probably looking at more than $3500 unless you can find some good used parts. Especially if you have someone else do the build for you......$$$$$.
Old Mar 21, 2016 | 04:13 PM
James93LT1's Avatar
James93LT1
Veteran: National Guard
You will need to set a goal and assemble toward it.
It will take a combination of parts to reach your goal, the key to power is well matched parts.
For a fun street ride, I would recommend:
-Good aftermarket heads, 195's
-Mini Ram, or LT1 converted intake.
-1.6 roller rockers
-Good cam or convert to a better roller cam.
-Tune
-Headers
-True dual exhaust
-2600-2800 stall converter
-3.54 or better gears
Old Mar 21, 2016 | 05:56 PM
ovrebo1's Avatar
ovrebo1
Sell the car and buy a LT1/4 C4
Old Mar 22, 2016 | 07:55 PM
TA's Avatar
TA
To each his own, but there are plenty of fast L98s out there.
Old Mar 25, 2016 | 05:28 PM
cv67's Avatar
cv67
St. Jude Donor '05
Superram is legal in Ca converted LT1 or minram not
OP are you doing labor yourself or not
You can still make it a fun st car and pass Ca smog
Old Mar 25, 2016 | 09:02 PM
aklim's Avatar
aklim
Figure out who is going to do your dyno work first. It That is going to be at least $500 and up. For $3000 or less, to do what you want is going to take a lot of scrounging and used parts and you have to do the work yourself. I don't think the performance plugs are going to do you much good just as the throttle body spacer won't. So how fast is "a lot faster"?
Old Mar 26, 2016 | 09:04 AM
DanielRicany's Avatar
DanielRicany
-1.6 roller rockers
-Tune
-Headers
-True dual exhaust
Really great recommendation. I have a 85 with a Miniram, cam, AFR 195 Eliminator heads, long tube headers 1 3/4", a corsa true dual 2 1/2" exhaust, 1.6:1 roller rockers and 3.75 gears. My car is also a 4+3.
I absolutely love this combination. There is no better combination for my car than this IMO, other than more cubic inches. And the 4+3 makes it really great because I can drive in direct drive and ring out of the RPMs with the 3.75s or I can switch overdrive on while around town and it makes it seem like I'm driving a 4 speed with 3.08s.
Old Mar 26, 2016 | 04:09 PM
cv67's Avatar
cv67
St. Jude Donor '05
Hes in can and cant use big cams long tube headers or minirams
To Performance
