Rough going into reverse
Old Sep 3, 2002 | 11:16 PM
shooter's Avatar
shooter
Default Rough going into reverse
For some reason my 91 6-speed has gotten very hard to shift into reverse.
Forward gears are a little rougher but not bad. Have not had time to check lube level, just got back from 3000 mile road trip. Any ideas?
thanks ed
Old Sep 3, 2002 | 11:26 PM
Black88Vette's Avatar
Black88Vette
Default Re: Rough going into reverse (shooter)
You probably already know this, but you said any ideas so here goes: Do you put it in a forward gear before going to reverse? I have to on mine or the gears will grind. I don't know much about trannies, but they say that when you do this it helps line the sprockets up. Just a suggestion. :cheers:
Old Sep 3, 2002 | 11:44 PM
silver & red CE's Avatar
silver & red CE
My gearbox had the same troubles, I swapped the fluid using GM factory lube, no change. I swapped the lube to Castrol Synthetic 10W-60 (from the BMW dealer, it's ZF approved), installed a Hurst shifter and bleed the clutch. Now it's smooth a silk. If I was you, I'd swap the fluid and bleed the clutch first, chances are it's never been done.
Eric
Old Sep 4, 2002 | 10:18 AM
shooter's Avatar
shooter
Default Re: Rough going into reverse (silver & red CE)
Thanks I'll try that this weekend. ed
Old Sep 4, 2002 | 10:41 AM
halver's Avatar
halver
check the clutch fluid level,any effect if you pump clutch? bleed system if that is the case :seeya
To Rough going into reverse
