Catch can
Old Mar 25, 2016 | 01:19 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Default Catch can
anyone here running a catchcan?
If so what brand?
I'm getting a lot of leak out my seals.
Wanting to redo the PVC system with a catch can
I don't want it open, I want to pull a vacuum on the crankcase
Old Mar 26, 2016 | 02:31 AM
LT1inaMGB's Avatar
LT1inaMGB
If so what brand?
I have mine hooked up like this and it works fine.
PCV.doc
Jim
Old Mar 27, 2016 | 11:50 AM
BrianCunningham
thanks
Old Mar 27, 2016 | 05:22 PM
dizwiz24's Avatar
dizwiz24
If so what brand?
do you have a check vAlve on your pcv system?
if not, the boost goes thru the pcv system the reverse way (from what is intended) and pressurizes the crank cAse when you are in boost.
im also running an oil catch can off my pcv system (with open breathers). i get a little bit of oil in it. my theory is its from some mild blowby that occurs under boost.
if i did not have the catch can there it would get sucked right into the intakr manifold the moment i let off of the gas after being in boost.
this would dirty intake manifold, intake valve, heads, and piston tops.
so thats why i run an oil catch can. i think its a good idea.
i do not have it plumbed to pull a vacuum on the crankcase. some guys claim that can even add some hp by promoting better piston ring seal.
Old Mar 28, 2016 | 07:31 AM
dizwiz24's Avatar
dizwiz24
If so what brand?
to answer your question, im running an elite engineering can (the lsx people use these all the time due to the problems that they have with oil blowby being sucked into pcv)....
i think you can plumb it the way you want to to pull a vacuum on the crankcSe under boost.
ask this question in the c5 forced induction section and they can help you out
Old Mar 28, 2016 | 10:27 AM
ANTI VENOM's Avatar
ANTI VENOM
Have you looked into any of the systems that "pull" from the exhaust? Just curious. Maybe they don't work well with muffler cars. I really don't have any knowledge of these systems but will need one pretty soon.
Old Mar 28, 2016 | 11:55 AM
BrianCunningham
I the valve is setup to pull a vacuum under idle,
and keep the boost in the manifold under boost
But it doens't pull a vacuum under boost, it just vents
right now I have a short loop similar to the stock setup
I'm thinking a two can setup since I dont want to get oil on th MAF
Old Mar 28, 2016 | 12:01 PM
LT1inaMGB's Avatar
LT1inaMGB
I have the catch can plumbed to the intake tube between the air filter and the supercharger inlet. I haven't measured it but I think there is enough vacuum in that area to vent pressures from the crankcase. I also have the MAF next to the air filter so the metered air stays behind the MAF
Old Mar 28, 2016 | 12:03 PM
dizwiz24's Avatar
dizwiz24
mines speed density so i dont have a maf to worry about getting oil on
Old Mar 28, 2016 | 12:32 PM
BlowerWorks's Avatar
BlowerWorks
Supporting Vendor
Hi Guys !
First we need define what it is you are trying to do. The PVC system and the Crankcase Vent system are two distinct systems.
The PVC system is a good system as it keeps the engine clean. The PVC system has nothing to do with crankcase venting. Other than an in-line check valve on the PVC I see no need for a catch can. Won't hurt anything but a lot of time & plumbing for what ? And the PVC system has nothing to do with oil seeping out here and there.
Now the crankcase venting system is another story altogether. You always want max venting on your crankcase to avoid oil leaks under boost or oil dipsticks being blown out.
And if you need a catchcan maybe you should be looking at an engine rebuild. Just run an open vent with proper baffling on each valve cover. If the vents start dripping oil you have a tired engine. A decent engine with a proper build will blow no oil out the vent.
The reason these vents are sometimes ducted to the air inlet is all about emissions. If you must do so and are blowing a lot of oil then yes a catchcan is a great band-aid !
Best regards,
greg
Old Mar 28, 2016 | 12:39 PM
BrianCunningham
I'm not blowing oil, its leaking
I want to keep the crank under a vacuum to help fight this
Old Mar 29, 2016 | 08:08 AM
BlowerWorks
Supporting Vendor
Under normal light pedal throttle the PCV system will draw fresh air thru the crankcase. Maybe that's a light vacuum.
Under WOT, with or without a blower, it's not possible to maintain a vacuum. Perhaps an air pump evacuating the crankcase is as close as you can get.
Old Mar 29, 2016 | 12:41 PM
BrianCunningham
Do you have a diagram of how you setup your systems?
Old Mar 29, 2016 | 01:35 PM
BrianCunningham
Found this on you site
Old Mar 30, 2016 | 03:08 PM
BlowerWorks
Supporting Vendor
Hi Brian !
If you go to my website then to the "Downloads" towards the end there is my C5 Installation Guide. You can start at page 122 and find a nice diagram on page 128 that is emissions legal.
greg
Old Mar 30, 2016 | 03:35 PM
armysnipe's Avatar
armysnipe
I'm using a can from mightymousesolutions.com. Check out their website. They've even improved their product from when I purchased mine. At the time they sold a catch can for boosted vehicles that had a built in PVC. I have been happy with mine so far. I'm running -10 lines from my valve covers to the catch can.
Old Mar 31, 2016 | 08:37 AM
BrianCunningham
Originally Posted by BlowerWorks
Hi Brian !
greg
Just what I'm looking for
thanks
To Catch can
Old Mar 31, 2016 | 08:57 AM
BrianCunningham
Oh BTW how much for the catch cans?
Old Mar 31, 2016 | 11:36 AM
luckydekko's Avatar
luckydekko
<br >
Old Mar 31, 2016 | 11:58 AM
BrianCunningham
Originally Posted by luckydekko
<br >
OPEN VENT filter is not LEGAL
