Code scanner
Sep 4, 2002 | 09:46 AM
Code scanner
Which one should I get?
Sep 4, 2002 | 09:58 AM
Re: Code scanner (alphado)
http://www.c4vettes.com/ecm.htm
[Modified by JonM, 9:04 AM 9/4/2002]
Sep 4, 2002 | 10:29 AM
The clip sounds about right, unless you are a 95-96 car.....what year??
Sep 4, 2002 | 10:46 AM
Re: Code scanner (Goody)
1990, what do you use to decode the codes with?
Sep 4, 2002 | 10:55 AM
Autoxray. Fairly inexpensive, provides good information and easy to use. About $150. The one that will work on both OBD I or OBD II systems costs about double that.
Sep 4, 2002 | 11:35 AM
Re: Code scanner (ittlfly)
I use the test light that I keep in the car........I also have a list of the codes in there :seeya
Sep 4, 2002 | 11:53 AM
Read this
Sep 4, 2002 | 12:35 PM
can you test a '94 with the obdII connector with a paperclip? :cheers:
