1. Remove wheels
2. Unclip the parking brake spring from the caliper using vice grips (pull and lift up)
3. Unbolt Caliper and secure with a bungy cord to keep stress off brake line
4. Compress calipers with C-Clamp slowly (suck some fluid out of the master cylinder reservoir with a syringe)
5. Push out old brake pads, clean everything with brake cleaner, and lube the slides and any contact surfaces.
6. Reinstall new pads and everything in the reverse order.
Street only? - they are fine, have them on the wife's 04
One track day? maybe
two track days? time for new pads
autocross? maybe
Street only, mine suck!! They squeak worse than the other pads and the grey dust is so bad I have to clean my rims after I drive it. Plus it gets all over the Corvette
