Internally or Externally balanced ???
Old Sep 4, 2002 | 03:51 PM
vvv90's Avatar
vvv90
Default Internally or Externally balanced ???
My friend posed this question to me because I told him I was replacing the clutch and flywheel with a singlemass aftermarket. He asked if my motor needed to be re-balanced if I replace the flywheel.
do I ?
I'm guessing i don't have to pull the motor and balance the thing just to replace the flywheel :crazy:
Old Sep 4, 2002 | 04:46 PM
vettmech's Avatar
vettmech
Default Re: Internally or Externally balanced ??? (vvv90)
you are right.......get one made for your car and engine and you'll be fine :seeya
Old Sep 4, 2002 | 05:01 PM
JonM's Avatar
JonM
Keep your friend away from your tools and car. :yesnod: :lol: :yesnod:
Old Sep 4, 2002 | 05:49 PM
vvv90's Avatar
vvv90
Default Re: Internally or Externally balanced ??? (JonM)
I just emailed him this thread :lol: But seriously, his motor is badazz and he knows a lot about cars. His motor needs to be balanced with the flywheel attached. (500HP+ N/A 347ci) I'm not sure why, that's why I posted this.
Old Sep 5, 2002 | 03:09 PM
rms8's Avatar
rms8
3rd Gear
VVV90 had indicated that he was going to go with an aluminum flywheel. I am a FORD guy, so if you change the flywheel on a sml blk Ford, you have to know if it has the 50 or 28 oz. off-set since these motors are balanced EXTERNALLY! I did not know if the Chevy was an internally or externally balanced engine. By going with an aluminum flywheel, you are making a dramatic change to the rotating mass, and on an externally balanced engine, this would be disastrous if not compensated for! There, my 2 cents! Just looking out for my friend.....even if he drives a Chevy. :yesnod:
Old Sep 5, 2002 | 03:15 PM
vettmech's Avatar
vettmech
Default Re: Internally or Externally balanced ??? (rms8)
Wellllllll When you change stuff around like that ......... yeah you gotta pretty much take it apart and balance it. I was under the impression that it was just a general replacement. ............... :seeya
Old Sep 5, 2002 | 03:16 PM
scorp508's Avatar
scorp508
There, my 2 cents!
Hey who said the Ford guy could have 2 cents? He gets to start with 1 and work up! :jester
Old Sep 5, 2002 | 03:26 PM
JonM's Avatar
JonM
rms8...you forgot something ... :lol:
http://www.svs.com/users/zim/mustang/images/0900d.jpg
Old Sep 5, 2002 | 03:51 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
The new flywheel has to be balanced to the same specs as your old flywheel. They should be able to make the adjustment to the new flywheel by using the old one. On the LT1, the flywheel does have a weight on it for balancing the engine. You must compensate for this on the new flywheel.
Old Sep 5, 2002 | 05:36 PM
rms8's Avatar
rms8
3rd Gear
Default Re: Internally or Externally balanced ??? (Vette92)
Vette92:
so your post is to imply that the LT1 is an internally balanced engine? If it was an externally balanced engine, AND he wanted an aluminum flywheel, then he would defeat the weight savings if he had to load the flywheel back up to meet the originals specs. I think his original intentions were to avoid balancing the motor. So I just wanted to make sure that he would not run into any problems buy going with the lighter flywheel.
Old Sep 5, 2002 | 06:03 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
No the LT1 in externally balanced.
The weight savings is still there. The flywheel will usually simply have a weight on it. You either leave the weight for externally balanced engines or you take it off if it is internally balanced. The weight does need to be in the same area as the stock weight is. The flywheel assembly does not have to "weigh" the same.
Old Sep 5, 2002 | 06:09 PM
rms8's Avatar
rms8
3rd Gear
"The weight does need to be in the same area as the stock weight is"
And that is what I meant. The cost of switching to the aluminum flywheel just to weight it back down again would not be worth it.
Old Sep 5, 2002 | 06:10 PM
vvv90's Avatar
vvv90
Dude, you have no idea. Hey Rob, post a link to your car.
Old Sep 5, 2002 | 06:12 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Put the crack pipe down. You are still saving lbs on the rotating mass. You either put a weight on the flywheel (only a couple onces anyway) or you add heavy metal to your crank to internally balance it. I personally don't find the aluminum flywheel a benfit in street driven cars anyway and run a single mass steel Camaro flywheel which is lighter than the stock dual mass by quite a few pounds and my engine is internally balanced.
Old Sep 5, 2002 | 06:23 PM
vvv90's Avatar
vvv90
Well then that's something you and rms8 agree on. THAT's why I posted this thread saying "singlemass aftermarket" flywheel and not aluminum, because rms8 talked me out of it for the same reason. But I still had concerns about balancing the Fbody flywheel. I apologize for giving RMS a bad name about balancing because I did not disclaim that he was talking about aluminum flywheels. THEREFORE.....
....Do I need to conern myself about balancing it? Maybe, but I just wanted to make sure I didn't need to to anything to the motor and I guess I don't, so thanks for everyone's input. When it comes time to buy it, I'll post another thread asking which part number.
[Modified by vvv90, 4:25 PM 9/5/2002]
Old Sep 5, 2002 | 06:31 PM
jmr302's Avatar
jmr302
It's not the total weight of the flywheel that matters as far as balancing the rotating assy. Just gotta make sure that the balance weight on the new flyhweel is the same weight and in the same place.
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
vvv90,
If you buy a new stock Camaro flywheel, they come already balanced for LT1 motors and can bolt right on without having to take it to a machine shop with your old flywheel to have them match balanced.
Old Sep 5, 2002 | 06:42 PM
thetorch's Avatar
thetorch
Vette92 is exactly right. The LT1 is externally balanced. I have done this exact conversion on a 96 LT4 with a Fidanza aluminum flywheel. The flywheel was actually too heavy and 15 oz had to be removed. We took the original flywheel and had the new flywheel balanced to match the stock one. I would HIGHLY recommend that you verify the balance of the new flywheel against the stock one.
To Internally or Externally balanced ???
