Gaskets.........
Old Sep 4, 2002 | 05:41 PM
Hi-psi's Avatar
Hi-psi
Default Gaskets.........
Guys,
On a '94 LT-1, what all gaskets are needed for a head/cam swap, and
where is the best/cheapest place to get them?
Thanks.
Old Sep 4, 2002 | 05:44 PM
Hi-psi's Avatar
Hi-psi
Default Re: Gaskets......... (Hi-psi)
Also,...I know most GM's use those crappy torque to yeild head bolts that you can't reuse,....so will I need knew head bolts too?
Thanks.
Old Sep 5, 2002 | 04:42 PM
Hi-psi's Avatar
Hi-psi
Jeez,.....SOMEBODY has to know..... :(
Old Sep 5, 2002 | 05:29 PM
Arisa's Avatar
Arisa
Don't reuse the head bolts! Get ARP head bolts.
Gaskets there are several to chose from.
I went with factory Impala head gaskets to help my quench a little.
Here are your choice of head gaskets for an LT1: (the info below was provided to me by Christian M.)
> 0.026" - Mr Gasket # 5716
> 0.029" - GM Impala SS # 12553160
> 0.039" - Fel-Pro FEL-1074
> 0.046" - Mr Gasket # 5715
> 0.049" - GM Camaro, LT4 # 10168457
You will need head, intake, throttle body, EGR, air pump & exhaust gaskets. And a tube of "The Right Stuff" for the front/ back of the intake.
Also possibly the rubber seals for the rear coolant bleed tubes in the heads & the little donut thingys on the bottom of the factory headers if you are using the factory exhaust
Neal
[Modified by Arisa, 4:35 PM 9/5/2002]
To Gaskets.........
