LT4 with LT1-edit having VATS issue
Thanks in advance.
I saw this yesterday and thought it would be interesting "to watch"!
Why is the original "non-tuneable"? That requires some explanation. The 2 cars aren't even similar in vehicle communications (maybe a poor choice of word but .....
It runs with the OE PCM and that maybe confirms my thoughts. The Corvette PCM is communicating with a very different CCM/BCM (call it what you like). The F-body isn't spec'd to communicate with the same CCM/BCM. Can it be done? I've NO IDEA. I ain't that smart BUT it seems very obvious that it's very likely your situation "that you've created"?. I don't even know that with the 2 FSM side by side it could be sorted. Someone very likely knows BUT .. Either the entire CRANK & FE needs removed from both the car and the PCM desired.
Maybe - just maybe you've got a bad PCM or maybe, just maybe a bad tune ....
What is the label on the f-body PCM?
I'd say the hardware isn't compatible ..... You mention the "SECURITY" light so it can be assumed that the CCM is still in the mix.
A quick glance at the CCM-AWAKE/ON/OFF it seems the car is maybe doing just what it is supposed to do. If the CCM doesn't see engine RPM it shuts off in 5-15 seconds. In instances it can do 30 seconds. The CCM isn't going to let the car run until it sees a "VALID" PCM/Engine configuration. You've proved this because the car runs with the correct PCM installed. Can the CCM be programmed for the f-body? Very unlikely. Like I said I just ain't that smart.
Do you have the FSM for the car?
***I would scan the CCM for DTC's and maybe expect a DTC 81 (Invalid Vehicle Configuration)
The cut-off is perhaps happening when the CCM finally sees through the communications the "INCORRECT/INVALID" combination and takes action. I didn't look very far to arrive at my thoughts and when I saw you mention "SECURITY" light I just thought CCM.
I actually thought I'd "poke around" looking for "INVALID VEHICLE CONFIGURATION" bypass, in later BCM things can be manipulated but I don't know that the CCM in '96 could be manipulated. It required programming when replaced but modifying after an initial programming I'm unsure of.
