Alternator Mounting Bolt Info Needed
On a dealers shelf you might find a 12337993 but it could be a "hit-miss".
Went looking with my new LED flashlight and lo and behold...found the bolt laying on the frame!!!
But now this is where something strange is going on:
Retrieved the bolt and went to put it back in the alternator but it would not tighten down...thought oh great the alternator threads are stripped out! I checked the bolt threads and decided to try running the bolt through a die; grabbed the thread pitch gauge and the bolt was not metric....is it a 3/8 x 16, and the head does not indicate a metric bolt....???....
Checked the alternator threads and yep they are 10 x 1.5...
Removed the same looking bolt out of the AC compressor (hidden behind ASR in picture) and it is also a 3/8 x 16??
Now I have had this car for over 10 years and did swap alternator from a '95 Corvette and this '96 some years ago....but pretty sure I kept the same bolts on each car..???
IDK....off to ACE Hardware to see if they have the correct bolt, if not then call to local Chevy dealer.
This is just strange!!
Nearly every body fastener has the flange head. You could very likely just "borrow" one from another less critical position on your car.
A GM dealer may likely NOT have it on the shelf by part# but it seems you understand what you're looking for so if you just ask the dealer to check their "shop" hardware I'm very sure you can be helped and also with the correct "under-head" shoulder for the bracket stack. There's some very unusual mixes of hardware that continued with GM even after the change from the L98 to the later LT engines. It's very easy to confuse one's self. If you were doing a JY swap using a 3/8-16 by mistake is very easy and "yes" it would have eventually "shook out'. The 3/8-16 is something closer to a 9.5mm AND THAT ALLOWS THAT TO HAPPEN.
Shop a dealer (any brand) for your bolt to get the flange head. The under-head isn't near as critical but if you could you would like to avoid - "thread to head"
I have found the odd mix of SAE and Metric bolts on every GM car I have ever worked on, would have thought by 1996 GM would have fully converted to Metric sizes for everything, guess not.
Now I am wondering if I put a Metric bolt in the '95 Corvette along with the '96 alternator when I did that swap five five years ago. No longer have that car but will ask the current owner if he is missing that bolt.....if so...I have it.
