torque converter and lock-up
Old Sep 4, 2002 | 10:17 PM
corvette4life's Avatar
corvette4life
Default torque converter and lock-up
Can you get a 2400 R.P.M. stall converter for the 4L60E and still retain the lock-up?
Thanks,
Kerry
Old Sep 5, 2002 | 12:01 AM
vader86's Avatar
vader86
Default Re: torque converter and lock-up (corvette4life)
:confused:
At 2400 stall, it would lockup at 2400
Old Sep 5, 2002 | 01:07 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I believe the lockup clutch on a 4L60E is the same as on a 700R/4.
So if you get a 2,400rpm stall TC with a lockup clutch it should work fine with a 4L60E.
To verify you might want to go to the Level-10 web site (link on my page) to see if they have any confirmation.
Old Sep 5, 2002 | 05:58 AM
93 ragtop's Avatar
93 ragtop
Default Re: torque converter and lock-up (vader86)
:confused:
Not true. When the stall speed is 2400. This refers to how much the converter will flash to. This is a estimate only. It will change depending on the torque and hp output of the motor. The lock up is controled by the speed of the car and the throttle input. The stock mph setting is 41 or 43 mph and light throttle.
As far as someone making a 2400, I know vigilante has them, not sure about others.
Old Sep 5, 2002 | 09:49 AM
vader86's Avatar
vader86
Default Re: torque converter and lock-up (Red 86 4+3)
i know how a TC works, but im confused by his question, sounds like he doesnt think a new stall TC wont lockup anywhere
[Modified by vader86, 8:50 AM 9/5/2002]
Old Sep 5, 2002 | 11:57 AM
yoslambo1@cs.com's Avatar
yoslambo1@cs.com
i have a 2800 stall in my 700r-4. i had it custom made. :D
Old Sep 5, 2002 | 09:41 PM
corvette4life
vader what I'm asking is can I get a 2400 rpm stall converter and still retain the torque converter lock up. The stall speed and the Torque converter lock are two different functions. My understanding ( this could be wrong) is at WOT the converter does not lock up. On the 4L60E the lock-up is controlled by the ECM.
I hope I can get a 2400 stall converter and still retain the lock-up for lower RPMs at cruise speeds and better mileage. Also when the converter locks it keeps transmission temperatures down.
I see the converters in the catalogs with and without lock up for the 700R, but not for the 4L60E.
Thanks,
kerry
Old Sep 5, 2002 | 10:32 PM
BBA's Avatar
BBA
Yes...you can, as the 700R4/4L60 and 4L60E are made from the same parts, except for valve body and govenor.
In fact, it's hard to find ANY converter for a 700R4/4L60/E that does NOT have the lockup clutches. ( You can find non locking 700r4 converters though, and they are referred to as 'dummy' converters ).
[Modified by BBA, 9:35 PM 9/5/2002]
Old Sep 5, 2002 | 11:04 PM
vader86's Avatar
vader86
you would be lucky to find one that doesnt lockup
To torque converter and lock-up
