FMS 24#'s rule!!!
Old Sep 4, 2002 | 10:28 PM
87Beast's Avatar
87Beast
Default FMS 24#'s rule!!!
Already my average milage is better than the old stock injectors - which had some clogged ones, and I have a better idle. With the AFPR I've solved my rich problem too, now I must make sure I don't lean out the mixture.
Thanks everyone who steered me in the FMS and Holley direction :D
~ Seth
"I'll be your Huckleberry" - Tombstone
Old Sep 5, 2002 | 12:12 AM
Corvette0096's Avatar
Corvette0096
Default Re: FMS 24#'s rule!!! (87Beast)
:cool: :cheers:
Old Sep 5, 2002 | 12:26 AM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Default Re: FMS 24#'s rule!!! (corvette0096)
Great work! Yeah they make for a nice upgrade.
I do hate to burst your bubble though with the gas mileage though. Do to the fact that your injector constant is still set at 22 and you have 24 now, you calculation for your gas mileage by the car will be off.
You can verify what I am saying by making a note of your mileage at the next fillup, and then record your next fillup. Do the math and you will see what your really averaging.
This gets everyone! It shows I am getting 28MPG. My frequent fillups tell me different. :lol:
Great job though!
Old Sep 5, 2002 | 12:33 AM
Silver89's Avatar
Silver89
Default Re: FMS 24#'s rule!!! (ski_dwn_it)
:yesnod: :lol:
Old Sep 5, 2002 | 02:46 PM
USPRIDE's Avatar
USPRIDE
Since you have an '87. I belive you have a cold start injector. Did you dump it?
Old Sep 5, 2002 | 02:53 PM
Nathan Plemons's Avatar
Nathan Plemons
Mine is within 1 mpg of what it actually is. I keep detailed records EVERY time I get gas.
Old Sep 5, 2002 | 09:17 PM
87Beast's Avatar
87Beast
Default Re: FMS 24#'s rule!!! (USPRIDE)
No but when fuel was leaking thru the o-ring for the cold start inj. I was seriously thinking about blocking it but wasn't sure if it's easy
Old Sep 5, 2002 | 10:17 PM
Rich B.'s Avatar
Rich B.
I am curious - how stock is your engine, and what pressure are you running???
Old Sep 5, 2002 | 11:06 PM
IBEAM700's Avatar
IBEAM700
From: Looks like I picked the wrong week to stop sniffin glue Orlando
Id like to know what pressure your running also. I have a set of FMS 24# injectors. Iv got the AFPR set to 35PSI with the vacuum line disconnected, and im still running in the 700-800 mv range… :chevy
Old Sep 6, 2002 | 03:01 AM
87Beast's Avatar
87Beast
Default Re: FMS 24#'s rule!!! (IBEAM700)
The only stock part of the engine is the intake - I've yet to mess with that. The bottom end however carries the AFR 190, ZZ-9 cam, bored .030, headers, missing cat, Borla mufflers, and a few other items. No stroker yet but will someday along with ASM and TPIS intake.
Right now I have the fuel pressure set at 38 psi, because of a rich problem I had before... I may set it lower to 35 since it still is a little rich.
To FMS 24#'s rule!!!
