Engine Making Chirping Noise
Old Apr 10, 2016 | 02:19 AM
MrHappy66's Avatar
MrHappy66
Default Engine Making Chirping Noise
Hello!
My '89 keeps making this kinda loud Chirping noise. I'm having a hard time figuring out what it is. I thought it was the belt, so I did that little bar of soap trick and the sound was still there.
So I put my ear around the car and the belts sound normal but I found the area where the sound is coming from. It's by the engine block, where it says "Tuned Port Injection"(or where the engine air intake hose first starts). Anybody take any guesses on what it is?
Old Apr 10, 2016 | 02:44 AM
THE 383 admiral's Avatar
THE 383 admiral
that would be the Throttle Body. Possible small vacuum air / hose leak.
Old Apr 10, 2016 | 09:38 AM
antfarmer2's Avatar
antfarmer2
you could take the belt off to test.
Old Apr 10, 2016 | 01:43 PM
MrHappy66's Avatar
MrHappy66
Thank you guys!! One more question though, is the tensioner pulley supposed to shake vertically during while the engine is running?
Old Apr 10, 2016 | 02:08 PM
s carter's Avatar
s carter
it will bounce a bit
Old Apr 10, 2016 | 02:56 PM
cv67's Avatar
cv67
St. Jude Donor '05
Try running it without the belt
If it still makes noise see if the balancer is hitting the timing cover
If it isnt pull the valvecovers off you may have your answer there.
Old Apr 10, 2016 | 03:30 PM
C4boy's Avatar
C4boy
Check for pulley alignment, too. See if the belt is riding an edge of any pulley's that aren't grooved. You can try squirting some water on the belt and see if the chirp goes away.
To Engine Making Chirping Noise
