ZF 6 bolt torque specs
Old Apr 11, 2016 | 12:13 PM
WRC7732's Avatar
WRC7732
Default ZF 6 bolt torque specs
Hey all,
Does anyone know or have a listing of torque specifications for the various different bolts on the ZF6 speed transmission?
Specifically I need the torque spec for the input shaft bearing retainer plate/throwout bearing sleeve bolts. There are 6 Allen head bolts that in need to retorque.
Thanks,
Will
Old Apr 11, 2016 | 01:42 PM
don hall's Avatar
don hall
Send email to billb@zfdoc.com,
or call Bill Boudreau at (602) 319-6575.
Old Apr 11, 2016 | 01:45 PM
WVZR-1's Avatar
WVZR-1
Hey "Seabright" - How are you doing? Good to see you posting more frequently.
OP - the 6 you mention are 16LbFt and everything is documented in the FSM.
Old Apr 11, 2016 | 01:56 PM
don hall's Avatar
don hall
Originally Posted by WVZR-1
Hey "Seabright" - How are you doing? Good to see you posting more frequently......
Doing fine, thank you. Posts are infrequent, as I learned I'm not as smart as I thought I was.
Enjoy reading your resolutions to problems posted.
You are a valuable asset to the forum.
Old Apr 12, 2016 | 07:59 AM
WRC7732's Avatar
WRC7732
Perfect. Thank you, good sir.
To ZF 6 bolt torque specs
