Replacing Shocks - 1994 C4 Coupe
Old Apr 12, 2016 | 12:16 AM
WPK's Avatar
WPK
Default Replacing Shocks - 1994 C4 Coupe
Quick Question - from someone not very mechanically inclined.
My 1994 doesn't appear to have struts - just some aftermarket bilstein shocks. Nothing adjustable - just shocks.
So, is replacing the shocks as simple as unbolting the old ones and bolting in the new ones?
-WPK
Old Apr 12, 2016 | 01:51 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
You're here in Sonora.
Got the parts? I've got the tools
PM me
Old Apr 12, 2016 | 07:30 AM
aklim's Avatar
aklim
-WPK
If the are aftermarket Bilsteins, why are you replacing them? If they are worn, they can be rebuilt by sending them in. I did after 10 years and they didn't even bother to look at them. Just sent me a couple of new ones.
Old Apr 12, 2016 | 08:41 AM
TorchTarga94's Avatar
TorchTarga94
1. They are probably original bilsteins if they have black dust boots.
2. Yes you just unbolt the old & bolt in the new. Support vehicle on jackstands first.
Old Apr 12, 2016 | 09:51 AM
antfarmer2's Avatar
antfarmer2
PM me
What a deal!!!
Old Apr 12, 2016 | 12:21 PM
aklim's Avatar
aklim
It would be worth his while to verify. Aftermarket Bilsteins are yellow.
Old Apr 12, 2016 | 12:45 PM
2ooo-C5's Avatar
2ooo-C5
sorry to jack the thread.
I just replace the original bilsteins. So, I can send the originals in and they will rebuild them? Does the forum have a contact? For $400 shocks I will totally send them in and put them on the shelf till these wear out.
Old Apr 12, 2016 | 12:53 PM
aklim's Avatar
aklim
If they are a solid yellow with BA5-7000 for front and BA5-7001 for rear, I would give Bilstein a call and see how to send it back
Old Apr 12, 2016 | 12:55 PM
2ooo-C5's Avatar
2ooo-C5
Im a z51 so those are not the part numbers.
But I know they are factory Bilsteins.
Old Apr 12, 2016 | 12:56 PM
aklim's Avatar
aklim
Won't hurt to give them the part numbers and ask
Old Apr 12, 2016 | 01:00 PM
TorchTarga94
Recent Aftermarket (last ten years)- Yellow with light blue dust boots (Nordschleife Nurburgring Sticker on them)
Old Apr 12, 2016 | 11:52 PM
WPK's Avatar
WPK
Default Yes, mine are aftermarket
Bought the vehicle in 2008 with 80,000 miles on it. Shortly afterwards, I had a local shop replace the original shocks with aftermarket bilsteins (blue sleeve).
The car now has two hundred and twenty thousand miles on it. I guess it's time for new shocks. The reason I didn't want to use the shop is because I was going to remove the shocks, send them in for free replacements, and then install the new ones when they arrived. The car would have to sit in the shop for quite a while.
It sounds like it's not too tricky. Thanks for all the input.
- WPK
Old Apr 14, 2016 | 06:15 AM
tmirisola's Avatar
tmirisola
I'm new to the C4 world and loving it. Tell me more about the Factory Shocks and what should I be looking for. My car has 17,000 miles on the clock. I don't think the shocks need to be replaced, but I would like to learn more about them. Thanks in advance :-)
Old Apr 14, 2016 | 07:33 AM
aklim's Avatar
aklim
- WPK
It's so easy a caveman can do it. Trust me.
Old Apr 14, 2016 | 07:36 AM
aklim's Avatar
aklim
Newest C4 is 96. That is 20 years old. I wouldn't trust the factory (came with the car) shocks. I'd replace them with something newer. Mileage wouldn't matter to me as much since things can deteriorate regardless of mileage. Dad used 10 year old tires simply because he didn't have the mileage on it. IIRC, it was around 20K and the car was kept indoors when it wasn't running and washed, etc. One day, the tire made a "thump-thump-thump" sound and he was sure it wasn't a bad tire. As he was pulling off the ramp, the tire shredded and took out a fender. Luckily he wasn't doing 70
To Replacing Shocks - 1994 C4 Coupe
