***HELP PLEASE***
Old Sep 5, 2002 | 01:33 AM
Kehrer923's Avatar
Kehrer923
Default ***HELP PLEASE***
Ok i went to the local track today and its a 1/8 mile. First time i have ever raced my vette, and look at my sig. it should be at least 450 hp. Well, I had to traction whatso ever, like i tried everything even rolling though the lights. I just smoked the tires in 1st and 2nd. (with 315 michelns)My best 60' was a 2.59!!!!! :eek: with a best et of 9.00. So what shoudl i do. Slicks, drag radials, suspension??? :confused:
Old Sep 5, 2002 | 01:39 AM
scorp508's Avatar
scorp508
Street tires + 383ci + 1/8th mile = Do not mix. :D
Grab yourself at least some drag radials.
Old Sep 5, 2002 | 01:45 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
at the very least drag radials.
Old Sep 5, 2002 | 12:21 PM
yoslambo1@cs.com's Avatar
yoslambo1@cs.com
Default Re: ***HELP PLEASE*** (Kehrer923)
i have a 383 but its automatic. if i feather in the gas i dont spin much. if i mash it its scary. i still havent raced on a track yet (oct 11 will be my first) but ive been practicing at stop lights! :jester what if you ease out of first & mash it in second? will you hook up then? :confused:
Old Sep 5, 2002 | 01:34 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
Learn how to slip the clutch. Also get some good tires on it, AVS Sports or Nitto Drags will help.
Old Sep 5, 2002 | 10:12 PM
tkrussell's Avatar
tkrussell
Default Re: ***HELP PLEASE*** (Vette92)
CarTest has an interesting simulation program that looks at performance mods and their effects. It includes friction coefficients of tires, etc.
For street tires, when I ran the simulation on a Vette with 400-500 hp, the optimal launch RPM was 1200-1400 for a 6sp depending on the hp, tire size, etc. Obviously, the Vette is "traction limited" as they say with street tires.
Old Sep 5, 2002 | 11:02 PM
Kehrer923's Avatar
Kehrer923
Default Re: ***HELP PLEASE*** (tkrussell)
yea what would you guys recommend for all out drag slicks and wheels
Old Sep 6, 2002 | 11:11 AM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
You are welcome to borrow my ET Streets if you would like to see how your car takes to them. I will not be responsible for drivetrain parts though.
email me, we do not live far from each other. dba_consult@hotmail.com
Old Sep 6, 2002 | 09:13 PM
Red Rocket's Avatar
Red Rocket
If you want to drive to the track and be competitive with a 17" set up go with the 315 BFG Drag Radials in back and put in a line lock, assuming this is a six speed. If you do not mind changing tires, then go with a 16" ET Street set up and try and keep the launches under 3000 RPM"s. On Street tires and Nitto's I launch at idle (1000 RPM's), roll out and and hit it.
To ***HELP PLEASE***
