"Lurching" under light throttle
Old Apr 16, 2016 | 12:55 PM
tiger38117's Avatar
tiger38117
Default "Lurching" under light throttle
My '87 "lurches" under light or no throttle, like when coasting down in gear or cruising at 1500-1700 rpm or so. It's a rhythmic lurch or surge, strong enough to make your head bob. Step on the clutch or add a bit of throttle and the prob goes away instantly. Car runs great otherwise, and readings on vacuum gauge are normal.
Suggestions? The car is a Callaway, but I wouldn't think that would matter, this seems like an L98 problem. The car has 28,000 miles and is totally stock. No codes.
Old Apr 18, 2016 | 09:42 AM
DanielRicany's Avatar
DanielRicany
Maybe bad spark plug wires or fouled, bad, or incorrect gap on spark plugs?
Old Apr 18, 2016 | 11:09 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Not likely a spark plug, under decel.
Does it seem like it's going in/out of DFCO (Deceleration Fuel Cut Off)? Once you let off the throttle at most anything above ~1200 RPM, as the car decelerates, if you pay attention, you should feel it coast for a moment, then it chops all fuel and the engine really drags the car down in a more pronounced way. Once that happens, the engine is essentially shut off, until it hits about 1200 RPM or so and the injectors come back on. So plugs, wire, EGR, timing...no engine controls should matter in this mode of operation -the engine should essentially be "off".
Can you tell if it's doing this? If not, I'd investigate why...if it is, then going in/out of that mode, I'd be investigating that.
Old Apr 18, 2016 | 02:18 PM
VikingTrad3r's Avatar
VikingTrad3r
Oil Producer
could a screwy tps set this off? set too high at zero throttle?
or a pulsing/figity iac?
what gets deactivated when you stip slightly on the clutch?
not tranny related? i was thinking torque converter lockup having a small seizure at first but then i figured out you were a manual.
Old Apr 18, 2016 | 06:20 PM
tiger38117's Avatar
tiger38117
Good idea, but my 6th sense doesn't feel like that's gonna be it. The issue happens most under light throttle, like it you were navigating a parking lot or cruising in 4th at a city speed. Very light throttle seems to be the common variable
Old Apr 18, 2016 | 07:40 PM
ex-x-fire's Avatar
ex-x-fire
I'd ohm the injectors.
Old Apr 18, 2016 | 07:48 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
OK...that is a totally different operating mode that what you said originally;
"no throttle, like when coasting down in gear or cruising at 1500-1700 rpm" ....is very different than rolling through a parking lot in 4th gear. I think I understand you a little better now.
Typically surging under those conditions can be caused by:
*Lean A/F ratio
*Overly advance ignition timing
*Leaking/open EGR
*erratic sensor outputs
Old Apr 25, 2016 | 07:35 PM
VikingTrad3r
Oil Producer
Default op did u track it down?
i suddenly started to get it in my 87 as u described.
*Lean A/F ratio
*Leaking/open EGR
To "Lurching" under light throttle
