Vette is backfiring constantly when Let off gas
Old Sep 5, 2002 | 11:58 AM
dscottr's Avatar
dscottr
Default Vette is backfiring constantly when Let off gas
The backfiring is driving me nuts. I just recently did all of the mods in my signature, and now every time I accelerate aggressively, the car backfires as soon as I let of the gas. The car was running very rich. 10 point something Air fuel ratio. I talked to the guys at Fastchip, and they said it was unusual for someone with my mods. Fastchip reprogrammed my custom chip, and the car seems much quicker now. It will even idle with the A/C on now, but the backfiring is still happening. What are the common causes of backfiring? :confused:
Old Sep 5, 2002 | 12:19 PM
Nathan Plemons's Avatar
Nathan Plemons
Default Re: Vette is backfiring constantly when Let off gas (dscottr)
Are the cats intact? If you've got headers, and it's running a little bit rich, coupled with a small exhaust leak and you'll throw a flame out of your tailpipe!
If you've still got cats on there it should be very quiet.
Old Sep 5, 2002 | 01:00 PM
vettmech's Avatar
vettmech
Default Re: Vette is backfiring constantly when Let off gas (Nathan Plemons)
Do you still have the AIR system intact?......... this supplies air to the exhaust system and will cause some backfiring and it's worse if the diverter valve isn't working. Is the vacuum hose hooked to the pump?.... that is a major cause of backfire (no vacuum hose)
Is it just one POP or is it cracking and popping as you slow down....... usually a single hellacious POP is the diverter valve and some cracking and popping as you slow down is usually from the system working properly with that fat mixture.........which might be worse with a cold engine :seeya
Old Sep 5, 2002 | 01:05 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
If you are running too rich it can backfire or if you have an exhaust leak it can cause bad backfires.
Old Sep 5, 2002 | 01:22 PM
dscottr's Avatar
dscottr
Default Re: Vette is backfiring constantly when Let off gas (Vette92)
Everything is stock except for the Corsa catback. The stock cats are still there. The vacuum hose is still attached. I am not sure about any leaks, since I am no mechanic. I am planning on doing TPIS long tube headers, so I guess I will live with it until I do the new exhaust and then have the garage check for exhaust leaks.
Old Sep 5, 2002 | 01:25 PM
dscottr's Avatar
dscottr
Default Re: Vette is backfiring constantly when Let off gas (vettmech)
Usually it is popping and cracking, but everyonce in a while I get real big bang mixed in there.
Old Sep 5, 2002 | 02:44 PM
vettmech's Avatar
vettmech
I'd say find out why it's so rich and fix that then the problem will go away....... :seeya
Old Sep 5, 2002 | 03:24 PM
RadPolo96's Avatar
RadPolo96
My brother had the same problem you had in is 99 Z28. His was caused by the plugs you are using. As soon as he changes those Bosch platinum plugs it all went away.
To Vette is backfiring constantly when Let off gas
