My shifter is loose??
Old Sep 5, 2002 | 12:57 PM
Rearview's Avatar
Rearview
Default My shifter is loose??
I've ben noticing lately that my shifter seems to have some play in it. I don't remember it being there before. It also feels mushy when I upshift (especially in 2nd). At anytime (in gear or neutral) the shift **** has about 1cm of movement left to right and a little bit forward/backward. It is very easy to move it, so it doesn't feel like the whole transmission moves with it (although this could be the case, I don't know). Everything about the shifter/tranny is stock. If anyone has a suggestion as to the problem and how I can correct it, I'd appreciate it.
Old Sep 5, 2002 | 02:06 PM
STL94LT1's Avatar
STL94LT1
Default Re: My shifter is loose?? (Rearview)
The shifter has shims, maybe they worn, they are very easy to replace.
Or maybe just upgrade to the Hurst, it makes a world of difference.
Old Sep 5, 2002 | 06:13 PM
Rearview's Avatar
Rearview
Default Re: My shifter is loose?? (STL94LT1)
How do I get in there to it to see if something is loose or worn? My friend with the factory service manuals moved... :nonod:
Old Sep 5, 2002 | 06:40 PM
Tony.96LT4's Avatar
Tony.96LT4
You have mail
Old Sep 5, 2002 | 06:52 PM
Rearview's Avatar
Rearview
Default Re: My shifter is loose?? (Tony.96LT4)
Wow, looks like a bitch. :) Thanks,
To My shifter is loose??
