From: I could tell but then I would have to kill you
Now I have a IAC problem.
Okay, I got most of the bugs worked out, but now I have a Code P0506 "Idle Air Control System RPM Lower Than Expected" Could this be my TPS? :confused:
I may be wrong but I don't think that will be your tps............make sure you have no vacuum leaks, make sure the throttle plates are closed properly, make sure the PCV system is ok........no leaks , valve OK ect..........does it idle at the proper speed? :seeya
It's your throttle body plate position, you got it... readjust the idle screw on the throttle body... remember that autotap program i told you about :D You can set it and adjust the throttle for roughly 20 -50 IAC position. It (IAC) is probably bottomed out and cant adjust to give you the proper idle that the ecm is commanding.
Re: Now I have a IAC problem. (Mo_Bandy)
mo
It took me awhile for this. I just wasnt thinking I finally got it set at 30 right before I went to the track. Luckly I had a friend who had a good scanner, not the POS I have.
