Which spring leaf?
Old Apr 21, 2016 | 11:09 AM
pifo1964's Avatar
pifo1964
Default Which spring leaf?
Hi all
I need to buy a front spring leaf for my 93 and I notice there are several codes for the same leaf.
For example, FHC or FHA?
Which one fits? If any of the two fits...or perhaps both.
I see differences in the rubber at the ends og each leaf.
The sellers are telling the springs are por 84-96 corvettes, it´s that correct?
Old Apr 21, 2016 | 11:28 AM
WVZR-1's Avatar
WVZR-1
I have a '93 front here that was removed from a 30K mile recovered theft years ago along with the front suspension arms/spindle. A '93 has the "square" bumper in your upper image. Judging from various springs I've checked the transition was likely done in '92.
Theoretically only '88+ fronts will change and I'd prefer to match the exact configuration. Bumper or molded pad for the front. front trim heights appear to be different various year (close but different - I haven't compared in years).
Rears will fit all C4's, the fronts will NOT.
Are you actually in Uruguay? Shipping might be tough. I'm interested maybe depending on the shipping involved.
Old Apr 21, 2016 | 11:39 AM
Kevova's Avatar
Kevova
FHA 88-91 Base Coupe will fit through 96
FHC 88-91 Convertible will fit through 96
Both are fronts have same spring rate and firmer than 92+base springs
Old Apr 21, 2016 | 11:56 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Here.
http://www.corvetteactioncenter.com/...l#.USlImDcSv6k
Your welcome
Old Apr 21, 2016 | 12:00 PM
pifo1964's Avatar
pifo1964
So, both will fit my 93 coupe?
Old Apr 21, 2016 | 12:12 PM
Kevova's Avatar
Kevova
I would go with the FHA because you have a coupe, and so far away.
Old Apr 21, 2016 | 12:31 PM
pifo1964's Avatar
pifo1964
That would make sense, but as my car has the standard FE1 and looking at a table (copied below) from corvette action center forum, it says FHC......for FE1
I´m lost.....
Front spring data. Many more than I thought...
Not all yrs interchange....later yr C4 had changes in steering geometry that effected the springs physical dimensions or length and how it fit into the lower control arm. The variations were not nearly as wide as the rears were. Here, fronts varied by 30 or 40 lbs...rears went between 200 to 500.
* FRONT (18 springs - HMP is listed twice because internet data gave 2 N/mm rates)
Code #/in N/mm Year(s) GM part # GM Service Parts Catalog
FHB 590 [115.5] 1988-91 10048553 . . . . . . . . . . 7-E9 7-E13 7-E19
BMB 521 [102.0] 1984 14045782 . . . . . . . . . . - not in microfiche
AA 491 [96.2] 1990-91 17988598 . . . . . . . . . . 7-E13 7-E19
FHA 476 [93.1] 1988-91 10048552 coupe FX3 FE7 + L98 7-E9 7-E13 7-E19
FHC 476 [93.1] 1988-91 10048574 conv FE1 (SR) . . 7-E9 7-E1347-E19
FSK 460 [90.1] 1992-95 17997091 . . . . . . . . . . 7-E19
FSM 385 [75.4] 1992-95 17997093 . . . . . . . . . . 7-E19
HMZ?a 379 [66.5] 1986-87 14106617 coupe FE7 ___ . . - not in microfiche
FSR 374 [73.2] 1992-95 17999031 conv FE1 (SR) . . 7-E19
FSS 374 [73.2] 1992-96 17999032 coupe FE1 (SR) . . 7-E19 7-E20
HMP 362 [63.5] 1984-87 14106617 . . . . . . . . . . 7-E5
HMP 379 [66.5] 1984-87 14106617 . . . . . . . . . . 7-E5
HA 306 [60.0] 1989-95 22145203 coupe FE1 (SR) FX3 7-E13 7-E20
JA 306 [60.0] 1994-95 22145227 conv FE1 (SR) FX3 7-E19
...?b 306 [60.0] 1995 22173029 conv FX3 (ER) . . 7-E19 no 3 letter code
...?c 306 [60.0] 1996 22173028 coupe FE1 (SR) . . 7-E19 no 3 letter code
HMN 278 [54.4] 1986-87 14094457 conv FE1 (SR) . . -
HKX 276 [54.0] 1985 14094458 . . . . . . . . . . page 7-C24 microfiche
HMP 261 [51.8] 1986-87 14094458 . . . . . . . . . .
Old Apr 21, 2016 | 12:37 PM
WVZR-1's Avatar
WVZR-1
I have both styles FHA - earlier with the molded pad (removed from a '91 ZR-1 FX3) and the later with the "square" bumper removed from a '93 coupe FE1.
If you're interested use the email link with my "user ID". I believe there are maybe many errors in the posted charts through the years. A confirmation from a build sheet would be the only confirming code.
Old Apr 21, 2016 | 12:51 PM
pifo1964's Avatar
pifo1964
I sent a private message, or at least I think so....I´m not very good "handling the forum" and perhaps the message never arrived.
Old Apr 21, 2016 | 12:56 PM
WVZR-1's Avatar
WVZR-1
Didn't receive a PM - just click on my user ID and you should see PM and email choice. I prefer email but PM will work.
Old Apr 22, 2016 | 09:48 AM
exitwound's Avatar
exitwound
Could you just fit coilovers and forget the springs?
Old Apr 22, 2016 | 10:30 AM
pifo1964's Avatar
pifo1964
Please explain what are coilovers, my english is not that good.
A very good friend of mine is an official Good Year dealer and he is the best in everything related to tires, wheels and suspension.
Thanks!!
Old Apr 22, 2016 | 10:50 AM
pifo1964's Avatar
pifo1964
Thanks!!
silly me, insted of asking you I should have consulted Mr. Google
Old Apr 23, 2016 | 01:10 AM
blackozvet's Avatar
blackozvet
here's some spring info that might help,
https://www.corvetteforum.com/forums...84-96-z51.html
Old Apr 24, 2016 | 06:37 PM
pifo1964's Avatar
pifo1964
Just curious, why a convertible and a coupe from same year and with same suspension, have front leaf springs with different codes?
Old Apr 25, 2016 | 05:00 AM
blackozvet's Avatar
blackozvet
the convertible had a different leaf to raise the car slightly to give clearance for the x braces that were fitted to them.
Old Apr 25, 2016 | 06:11 AM
pifo1964's Avatar
pifo1964
That make sense.
Thanks!
To Which spring leaf?
