C4 Accelerator Problem
Old Sep 6, 2002 | 08:45 AM
Secrt007Agt's Avatar
Secrt007Agt
Default C4 Accelerator Problem
I notice that sometimes when I push down on my accelerator pedal, it will not depress. I have notied it periodically when I turn sharp & sometimes when I start off and try depress it ( floor it). I thought, motor mount, but they appear to be alright doing the standard test. I'm not familiar with the accelerator "box", for lack of a better word, under the hood. Any guidance would be appreciated. Thanks :confused:
Old Sep 6, 2002 | 10:59 AM
Wheelman's Avatar
Wheelman
Default Re: C4 Accelerator Problem (Secrt007Agt)
what year is your car? If it is a 92 or up then it will have traction control, otherwise known as a black box under the hood with the letters "ASR" on it. If your traction control is on and you floor it out of a turn i am assuming it wouldnt open up all the way, becuase flooring it when still in the turn could easily be disasterous.
hope this helps.
Old Sep 6, 2002 | 11:39 AM
rpuerzer's Avatar
rpuerzer
It appears that the traction control is operating (which adjusts breaks, throttle, etc.) to limit wheel spin. There is a traction control switch that will turn traction control off located under the running light switch. It lights up in the visual display above the console when it is off. Also, when traction contral is operation(adjusting the gas pedal) the display console indicates that it is operating. :flag :chevy
Old Sep 6, 2002 | 07:43 PM
JIMBO55's Avatar
JIMBO55
Default Re: C4 Accelerator Problem (rpuerzer)
anybody have a photo of that switch??? jimbo :crazy: :crazy: :crazy: :crazy:
Old Sep 6, 2002 | 11:09 PM
CowboyNVette's Avatar
CowboyNVette
Default Re: C4 Accelerator Problem (JIMBO55)
I believe its only on LT1s and LT4s....Its right above the head light switch
To C4 Accelerator Problem
