Eratic timing..... possible causes ?
Old Sep 8, 2002 | 02:29 PM
Rich B.'s Avatar
Rich B.
Default Re: (87SAM)
Very interesting, above about 3500rpm my tack reads about 5rpm :crazy:
...The waterfall display or the digital readout???...
Old Sep 8, 2002 | 10:43 PM
gcrouse's Avatar
gcrouse
Default Re: Eratic timing..... possible causes ? (BLUE ONE)
But timing still moves around a bit at 800 rpm, ( up to 90 deg every now and again
Again, if you're jumping 90 degrees you're triggering on crossfire from another cylinder. First thing to do is run it in the dark and look for stray sparks or arcing. Replacing plug wires, cap, and rotor will fix this.
Old Sep 8, 2002 | 11:24 PM
87SAM's Avatar
87SAM
Default Re: (Rich B.)
Rich B. That would be the digital display. The truth is I am not completly sure but I think the waterfall display may read some what correct. :(
[Modified by 87SAM, 8:24 PM 9/8/2002]
