Best Brake Fluid?
Old Sep 6, 2002 | 06:10 PM
VetteWave's Avatar
VetteWave
Default Best Brake Fluid?
Some people have suggested that DOT 5 synthetic would be great. Any comments?
Old Sep 6, 2002 | 06:19 PM
paulie's Avatar
paulie
Default Re: Best Brake Fluid? (VetteWave)
I have been using valvoline syn. and have very happy with it.
Old Sep 6, 2002 | 06:26 PM
Danno355's Avatar
Danno355
Ford's hi perf brake fluid. Ya, I know. Sounds scary to put a ford product in, but really, short of the $80 castrol, you won't find a better fluid. And the ford stuff is only $7.95 a bottle. Highly recommended by the folks at Baer Brakes.
Old Sep 6, 2002 | 06:51 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
Don't use DOT 5. I use the Valvoline Synthetic Dot 3/4 that comes in a big Gold bottle at Autozone. I change it about 3-4 times a year.
A lot of people talk about the Ford Blue fluid being an excellent fluid.
Old Sep 6, 2002 | 06:55 PM
Nathan Plemons's Avatar
Nathan Plemons
Default Re: Best Brake Fluid? (Vette92)
DOT 5 is NOT for performance vehicles. It's for show cars that rarely get driven as it won't absorb moisture, but overall it's pretty terrible.
I use the Valvoline stuff. It's some of the best stuff you can buy at a parts store without making a special trip somewhere. After I boiled my brakes at the track one day and had my pedal fall to the floor at 112 mph, brakes suddenly became a high priority. You just don't think about them until they are not there.
I flushed my fluid out and haven't had any trouble out of the new fluid. I am still going to flush it every year though as part of my yearly maintanence scheduel.
Old Sep 6, 2002 | 10:34 PM
tuband's Avatar
tuband
Cruise-In I Veteran
DO NOT USE DOT5.
That said, I am using the Ford HD. The Ford dealer is my next door neighbor and his shop is less than 2 miles away, plus the price was @$5.00 a can last time I purchased. When I upgraded brakes & changed the fluid there were several strands on the Forum and one of the strongest contenders were best fluid was the Ford (especially when you factor in the cost).
Old Sep 6, 2002 | 11:04 PM
gcrouse's Avatar
gcrouse
Default Re: Best Brake Fluid? (Nathan Plemons)
ATE Super Blue 200 fluid is great; Motul 600 is a little better- but more expensive and needs changing more often.
Here's a nice chart:
http://www57.pair.com/lane/bfluid.htm
Old Sep 6, 2002 | 11:52 PM
PeteL's Avatar
PeteL
From: And on the fifth day, subpoenas were served to Obama senior staff
Default Re: Best Brake Fluid? (gcrouse)
gcrouse, the ATE Super Blue and ATE TYP 200 are great fluids! Really good brake fluid without paying the $75 / liter for the SRF.
For those that must buy from a chain store, try to find something in a metal can, well sealed and flush at least every two years for street only use.
Or go to your local Ford Dealer and get the Ford HP DOT3 fluid, it is good brake fluid. Still needs to be flushed at least every two years for street duty.
DOT 5 fluid (silicone) is not usable in a vehicle with ABS brake systems. DOT 3, 4 or 5.1 is usable. I don't quite understand the 5.1 or "Super DOT" spec other then somebody who knows the stuff (involved with SAE) told me that it's a higher viscosity fluid (also some dampening effect on ABS -for good or bad).
In general: DOT 3 or DOT 4, metal can, sealed, highest WET boiling point you can find. Don't use DOT 5 (especially in an ABS vehicle).
Pete
Old Sep 7, 2002 | 12:17 AM
VetteWave's Avatar
VetteWave
Default Re: Best Brake Fluid? (PeteL)
Where can I buy the ATE Super Blue and ATE TYP 200 fluids?
Old Sep 7, 2002 | 12:56 AM
gcrouse's Avatar
gcrouse
First place has the best price; if you can get past the fact that they cater to Miata's.
http://shop.store.yahoo.com/specmiat...supblurac.html
http://www.spmotorsports.com/lubricants.html
http://www.fisher.org/store/category...=Brake%20Fluid
You might also call your local BMW, Porsche, or Audi dealers...
[Modified by gcrouse, 9:57 PM 9/6/2002]
Old Sep 8, 2002 | 04:29 PM
tkrussell's Avatar
tkrussell
The Doug Rippie site has a nice chart comparing the various brake fluids.
Castrol SRF is the best, but by far the most expensive.
Motul and Ford fluids are very good and less expensive.
GM specifically does not recommend Dot 5 with ABS brake systems.
Old Sep 8, 2002 | 04:46 PM
vette92_1's Avatar
vette92_1
I have not tried this yet, but one neat thing I have heard about the ford colored fluids (Blue and Yellow) Is, you can alternate between the colors, so when you flush out your fluid each time, you know you have gotten all the old fuild out when the color has changed to the new color. :yesnod:
Old Sep 8, 2002 | 04:59 PM
Dudeurgettnavette's Avatar
Dudeurgettnavette
:yesnod: :yesnod:
Old Sep 9, 2002 | 12:05 AM
bogus's Avatar
bogus
Default Re: Best Brake Fluid? (paulie)
:yesnod:
The stuff is DOT 3/4... I think somewhere in the trades, they call that 5.1...
[Modified by bogus, 11:10 PM 9/8/2002]
Old Sep 9, 2002 | 06:10 AM
93LT1's Avatar
93LT1
Default Re: Best Brake Fluid? (bogus)
FYI:
Fisher site seems to have the lower over all cost. Shipping was much lower.
Hank
Old Sep 9, 2002 | 08:01 AM
gtsyellow's Avatar
gtsyellow
Default Re: Best Brake Fluid? (93LT1)
motul 600 is probably the best dot 3/4 fluid i can think of off the top of my head, either that or AP racing 600. it will take about 100 more deg than your average valvoline dot 4 or the good ford dot 3.
To Best Brake Fluid?
