95 Starter Removal
Old Sep 6, 2002 | 07:20 PM
gdarwin's Avatar
gdarwin
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Default 95 Starter Removal
Geting ready to replace the starter in my new 95 :)
Any way to get to the top bolt without removing the exhaust? That big CAT (which takes way too long to cool down) is in the way.
BTW... 85 pictured below is for sale.
Old Sep 6, 2002 | 07:55 PM
riksvet's Avatar
riksvet
Cruising
Default Re: 95 Starter Removal (gdarwin)
The starter is very easy to replace. I just did mine 2 days before Carlisle. It was a matter of 2 bolts and removal of the wires and out it came. You do need to push it towards the front of the car then twist it if you have an auto trans like mine. Dont forget the gasket that goes around the gear where it enters the converter cover. All in all it took approx 20 min. I have a quick lift and park the car on it which made it this easy a jack and stands might take it a little longer.
Good Luck
Rick Springer
Old Sep 6, 2002 | 08:17 PM
gdarwin's Avatar
gdarwin
Cruise-In I Veteran
Default Re: 95 Starter Removal (riksvet)
Mine is a 6 speed and the CAT is right in the way of getting to the top bolt....
Old Sep 7, 2002 | 12:28 AM
gdarwin's Avatar
gdarwin
Cruise-In I Veteran
Job done... I had to put a serious dent in the CAT heat shield to get to the top bolt...
Took one of the manifold bolts off and it sheared off. Decided to take the other route. Will take the car to a muffler place to get that stud replaced.
New starter in... case closed. :seeya
To 95 Starter Removal
