only drive the car, don't race it or auto X
what brand of pads and rotors (should I need them also) should i look for.
it has the stock 9.5 wheels with the Z52 suspension if that helps any.
looking for braking improvement but under normal driving conditions.
should I increase size of rotor? etc.
thanks for the input. :seeya
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Re: 87:replacing brake pads (Lv2Driv)
:cheers: If you are happy with your braking, stay with stock GM. Try THE LAST DETAIL for good prices (tld.com I believe)
Carbons, Ceramics, etc are pricey and may not be worth the money for your driving habits
I bought a pair of Hawk pads and the breaking is way better now. I was running the raybestos pads before and was getting a clanking sound when you hit the brakes and it was impossible to get the things to lock up. So for a normal drive your braking distance will improve :yesnod: :yesnod: http://www.tirerack.com/brakes/resul...r=1987&x=0&y=0
